AX 15 Transmission swap questions - JeepForum.com
post #1 of 1 Old 11-16-2009, 08:02 AM Thread Starter
baldone
Guest
I just did a tranny swap in my 91 XJ 4.0L from an AW4 to an AX 15
The donor was a 92 XJ 4.0L
I have ended up with two problems since the swap.
Problem 1
The speedo doesn't work. I changed the VSS from the old AW4 to the AX15 and no speedo.
Problem 2
When coming to a stop and down shifting into 2nd the engine dies. The RPM's drop to zero adn I need to restart the engine. I have found that if I rev the engine a little it usually will stay running. Is there something I should adjust at the throttle body since the sawp? When idleing the RPM's sit around 800.
Any suggestions on the cause of the problem?
baldone is offline
2.8l XJ engine/transmission swap questions IainThornton XJ Cherokee Technical Forum 1 06-13-2009 10:25 AM
Transmission Swap Questions AX15 or NV3550? Spike101188 XJ Cherokee Technical Forum 2 07-08-2008 08:11 AM
Transmission Swap RLD831 XJ Cherokee Technical Forum 4 10-08-2007 02:54 PM
transmission swap bhysjulien XJ Cherokee Technical Forum 6 12-14-2005 06:18 PM
transmission swap motorheadmach1 MJ Comanche Technical Forum 7 04-03-2005 02:39 PM
