AW4 Overdrive problem - JeepForum.com
post #1 of 7 Old 12-05-2017, 09:50 PM Thread Starter
yorkee
I have a 2001 XJ, my overdrive problem is slightly different than others I read so far...
My xj is able to shift into overdrive every alternate start. If I have overdrive this trip, once I turn off the xj and restart it, I have no overdrive. I have to pull over, put it in park, turn off the jeep, then turn it back on to have overdrive. (just by putting it in park / neutral without turning it off doesn't do the trick.) I already clean the NSS couple times, I also adjust the shift cable. What else I can try?
yorkee is offline
post #2 of 7 Old 12-06-2017, 06:06 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Clean the connectors at the TCU and engine bay plugs.
http://cruiser54.com/?p=58
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 7 Old 12-06-2017, 06:53 AM
jtec
jtec's Avatar
2014 JK Wrangler
scan for codes - post ALL codes someone will advise. Especially if light is off.
Any other issues - anything?
Is there a remote starter?
jtec is offline
post #4 of 7 Old 12-13-2017, 05:15 PM Thread Starter
yorkee
Thanks for the response. I assume if there is any corrosion issue on the TCU connector, its likely from the engine bay because the unit is concealed and protected under the dash behind the firewall?
Also, is the TCU connector same between Renix vs 2001? I can only find pictures of its location from Renix..
No remote starter. Here is a laundry list: (amazingly still no engine light!)
P0443 - Purge Solenoid
P0135 - O2 Sensor
P0141 - O2 Sensor
P0155 - O2 Sensor
P0165 - O2 Sensor
P0130 - missing fuse #10
P0136 - Shorted O2
P0456 - PUAP rubber hose leak ?
P0705 - (TCM) wiring
I assume P0705 is the suspect cruiser54 mentioned about?
yorkee is offline
post #5 of 7 Old 12-13-2017, 06:10 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
P0135 - O2 Sensor
P0141 - O2 Sensor
P0155 - O2 Sensor
P0165 - O2 Sensor
P0136 - Shorted O2
Clean the under hood connectors and the TCU connector.
Your TCU is located in a different place than the rEnix one.
post #6 of 7 Old 12-14-2017, 07:08 AM
jtec
jtec's Avatar
2014 JK Wrangler
Are you SURE code is P0130 could it be p0030?
And the code p0705 will have me checking further
Trouble Code: P0705 (4.0L L6 VIN S Auto) A/T Check Shifter Signal Circuit Malfunction
jtec is offline
post #7 of 7 Old 12-21-2017, 10:36 PM Thread Starter
yorkee
cleaned the TCU connector with wire brush, still the same...
I need to go back to check if it is p0130 or p0030. the guy scan it and wrote it down on a piece of paper for me.
yorkee is offline
