Any tips second use of day misfire. XJ '89 4 litre - JeepForum.com
 2Likes
  • 1 Post By spiydr
  • 1 Post By K0LCB
post #1 of 6 Old 04-18-2019, 05:20 PM Thread Starter
Gremmy
1989 XJ Cherokee
Hi, Any tips for motor runs fine but if you turn motor off and restart for second journey the motor misfires every time.
Motor has to get completely cold overnight for it to run fine, then again second use misfiring bad down to 4 cylinders. The motor does not overheat runs as cool as a cucumber. Has lots of power.
Gremmy is offline
post #2 of 6 Old 04-19-2019, 06:31 AM
spiydr
If you let it idle for a few minutes does it clear up and run fine? Sounds very similar to a common heat soak issue.
Gremmy likes this.
spiydr is offline
post #3 of 6 Old 04-19-2019, 07:11 AM
K0LCB
K0LCB's Avatar
Check spark plug wiring
Gremmy likes this.
L. C. AKA LEONARD
Itís a Jeep thing
K0LCB is offline
post #4 of 6 Old 04-20-2019, 05:56 AM Thread Starter
Gremmy
1989 XJ Cherokee
Thanks guys.
Gremmy is offline
post #5 of 6 Old 04-20-2019, 06:20 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Go to www.cruiser54.com and complete tips 1,3,4, and 5.
Plugs, wires, cap and rotor should all be replaced every 30,000 miles.
Make sure your intake manifold bolts haven't loosened up.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #6 of 6 Old 04-20-2019, 07:30 AM
jtec
2014 JK Wrangler
how do plugs look - Wet Black dry tan? might be a clue.
A leaking injector or FPR - lowering fuel pressure and fouling plugs is my SWAG
jtec is offline
'03 4.0 misfire (only at higher rpm) Cam137 WJ Grand Cherokee Forum 8 09-09-2018 01:00 PM
2014 Cherokee MISFIRE P0303 Mlvr14 KL Cherokee 2014 & up 3 07-23-2018 09:18 AM
4.0 misfire codes and weird compression test results Dborns Jeep CJ Forum 65 06-28-2018 03:03 PM
Intermittent misfire Dborns XJ Cherokee Technical Forum 23 06-22-2018 02:43 PM
Misfire cyl 2 99 4.0 liter WJ autotech1 WJ Grand Cherokee Forum 11 02-17-2018 04:42 PM
