AC system removal - JeepForum.com
 1Likes
  • 1 Post By Fourspeedman
post #1 of 9 Old 01-20-2020, 03:55 PM Thread Starter
Groovystar
AC system removal
So I just brought home a 91 Cherokee 4.0. Really good condition for an all Florida Jeep. The A/C doesn't work. Fan blows good. I'm thinking of removing the A/C system to make a little more room for engine activities. Has anybody ever done this and did you have any issues removing it or after? I was told that the ultimate remedy to get it working again would be a complete system replacement. TIA
Groovystar is offline
post #2 of 9 Old 01-20-2020, 04:07 PM
car6car
AC problems have to be diagnosed first, usually it is one problem. Most likely, it is easier to repair AC than remove components.
Only once I had to fix about 7 AC problems, but it was 84 Corvette. I installed heater valve from some Dodge.
04 Grand (dead)
car6car is offline
post #3 of 9 Old 01-20-2020, 04:15 PM
Fourspeedman
Fourspeedman's Avatar
I used to yank the AC out of any car that it did not work. Then I wised up and learned about AC. There is only one moving part: the compressor. It is the usual culprit. It is not hard to learn but the tools are the real answer. You simply cannot work on AC without a good set of gauges. Then a vacuum pump for removing moisture. A digital postal scale for adding the correct amount of freon. Everything else is just "O" rings.
Cutlass327 likes this.
Mark in Queens- Home of Spiderman and the Ramones
Fourspeedman is offline
post #4 of 9 Old 01-20-2020, 05:10 PM
Mrtoyou
Mrtoyou's Avatar
This!
If I have to explain it, you probably won't understand anyway!
Mrtoyou is offline
post #5 of 9 Old 01-20-2020, 07:39 PM
car6car
everything is pretty easy except evaporator replacement.
Did you start repairing house AC yet?
04 Grand (dead)
car6car is offline
post #6 of 9 Old 01-20-2020, 08:27 PM
Fourspeedman
I have never had a house AC go bad. Noisy, but they work. Cars, always. So I got 609 certified for mobile systems.
post #7 of 9 Old 01-20-2020, 08:49 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Accumulator/drier system with an orifice tube, simple to fix. Expansion valve system with a drier, still easy, but can trick you. I don't remember what system they use on those ones.
I'd fix it. Nothing beats having A/C on a hot humid day.
Rick
Cutlass327 is offline
post #8 of 9 Old 01-22-2020, 07:49 AM
car6car
Let us say every part of your AC is bad. The only part you need to drive your Jeep is compressor bearing. (about $15 and you can probably install it w/o removing compressor.
04 Grand (dead)
car6car is offline
post #9 of 9 Old 01-22-2020, 09:11 AM
Saudade
1988 XJ Cherokee
If you wanted to remove it, you can swap the compressor out for the AC Bypass pulley.
https://www.dormanproducts.com/p-19728-34171.aspx
I would fix the AC.
Saudade is offline
