98 powertrain wiring harness diagram - JeepForum.com
post #1 of 16 Old 02-13-2012, 04:32 PM Thread Starter
truckntractorhi
im in the middle of swapping my auto to a manual. i need the diagram that tells me what pins do what on that connector to the passenger side rear of the engine! thanks!
truckntractorhi is offline
post #2 of 16 Old 02-14-2012, 11:12 AM Thread Starter
truckntractorhi
No one?
post #3 of 16 Old 02-14-2012, 12:09 PM
AZ Jeff
2014 JK Wrangler
I have the diagrams for a 2000, which are somewhat different due to the DIS. What connections are you trying to reestablish?
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #4 of 16 Old 02-14-2012, 07:49 PM Thread Starter
truckntractorhi
I'm I'm the middle of an auto to manual swap and I need to see what pins do what
post #5 of 16 Old 02-14-2012, 08:07 PM
mj40
1989 MJ Comanche
if its the oval one marked in the pic.. thats going to the aw's computer for the tranny shifts/loads..
mj40 is offline
post #6 of 16 Old 02-15-2012, 12:08 PM Thread Starter
truckntractorhi
Can't tell from just the hole but I'll go home and get a pic of what I'm talking about. In my 98 there are 3 connectors (on an auto) that need to be disconnected to remove the engine/trans/x-case
post #7 of 16 Old 02-15-2012, 04:21 PM
AZ Jeff
2014 JK Wrangler
That does not tell me diddly about what harnesses you are attempting to connect.
In case you are not aware, the wiring diagrams for the later XJ's are grouped according to subsystem function. For example, if the wiring is ignition related, that is in one section. If its transmission related, that's another section, and so forth.
Now what wires are you trying to connect?
AZ-Jeff
AZ Jeff is offline
post #8 of 16 Old 02-15-2012, 06:52 PM Thread Starter
truckntractorhi
ok its hard to describe so heres the pic!
post #9 of 16 Old 02-16-2012, 04:29 PM Thread Starter
truckntractorhi
need this soon....
post #10 of 16 Old 02-16-2012, 07:53 PM
AZ Jeff
2014 JK Wrangler
You circled what appears tp be one or two connectors that are ganged into a common wiring harness. (It's kinda hard to tell from such a far distance.)
Are the connectors currently mated? If so, what parts of the engine do the wires run to? Once I know that, I can give you the "pin-outs" for the connectors in question, since that is what you are looking for.
AZ-Jeff
AZ Jeff is offline
post #11 of 16 Old 02-17-2012, 06:31 AM Thread Starter
truckntractorhi
They are currently connected. It connects all of the engine and transmission sensors/injectors to the wiring harness on the jeep itself. I disconnected it when I removed the engine
post #12 of 16 Old 02-18-2012, 06:41 PM
grainofsalt
This may help you: http://www.berrysprinter.com/e-fiche...97-01/98xj.pdf
grainofsalt is offline
post #13 of 16 Old 02-19-2012, 06:46 AM Thread Starter
truckntractorhi
that shows it too me, but doesnt give me the pin outs to the connector
post #14 of 16 Old 02-19-2012, 07:15 AM
CCKen
CCKen's Avatar
You should have three connectors at that location, one is the connector from the auto trans Transmission Control Assembly to the Transmission Control Module, another is the connector from the Transmission Range Sensor (NSS) to the Transmission Control Module, and the other is connector C107, which has some transmission control wiring but also has alot of other non-trans wiring in it.
I'm not familiar with the wiring required for a manual transmission, or the switches/sensors mounted on a manual transmission; I do know that most auto transmission modules and sensors won't be reused.
The main thing you'll need is a different Powertrain Control Module (PCM), configured for a manual transmission.
Per the '98 parts catalog, the PCM for a 4.0, federal emissions, manual transmission is P/N 56041531AB
CCKen is offline
post #15 of 16 Old 02-19-2012, 09:45 AM
AZ Jeff
2014 JK Wrangler
The following from the 2000 FSM might help some more.
AZ-Jeff
AZ Jeff is offline
ARB Heavy Duty Headlight Wiring Harness or eAutoworks H4 Harness H4 MCObray XJ Cherokee Technical Forum 38 02-15-2017 11:47 AM
Mix matched wiring harness/engine/tranny.........could use a wiring diagram dadstoy XJ Cherokee Technical Forum 1 08-15-2009 11:58 AM
Scored a Trailer Wiring Harness at Junk Yard for $0, need wiring diagram photonut13 XJ Cherokee Technical Forum 1 04-12-2008 01:39 PM
Wiring diagram TBLimited XJ Cherokee Technical Forum 1 05-18-2005 06:57 PM
wiring diagram 90 xj ? shovelhead XJ Cherokee Technical Forum 2 02-16-2003 06:13 PM
