97 Fuse Panel Diagram Needed - JeepForum.com
post #1 of 2 Old 05-04-2006, 02:50 PM Thread Starter
Alan & Tanya C.
Guest
While troubleshooting my recent backup light problem, I must have replaced one of the fuses in the incorrect slot, as all my gauges are now out. I don't have an owner's manual so I need someone to describe the fuse panel layout so I can get them straight again. 97 XJ 4.0 auto, fuse panel is under dash on passenger side. Please include amp ratings too so I can double check those to make sure everything is correct.
Thanks in advance!
Alan
Alan & Tanya C. is offline
post #2 of 2 Old 05-04-2006, 05:28 PM
jeepngeorge
Google is your friend
Clicky Clicky
or for the lazy................
Posted by Demonmonkeydog on January 20, 06 at 14:54:39:
Found my owners manual. A couple of people have requested this, so here it is. This diagram probably works for all 1997-2000 models.
Numbers correspond to #s on the fusebox.
1. Pwer Outlet 25 amp
2. Cig Lighter 25 amp
3. Left Headlight Hi Beam 10 amp
4. Left Headlight Lo Beam 10 amp
5. Right Headlamp Lo Beam 10 amp
6. Instrument Panel Dimmer 5 amp
7. Left Parking Light 10 amp
8. Open
9. Headlight Delay, Overhead COnsole Cluster 10 amp
10. Open
11. Run/Start Ignition, Day Running Lights 20 amp
12. R. Window Defrost, Turn signal, Hazards 10 amp
13. Open
14. Heated Mirrors 10 amp
15. Power Locks 25 amp
16. Right Headlamp Hi Beam 10 amp
17. Radio 15 amp
18. Open
19. Starter Relay 10 amp
20. Trailer Tow Pkg 10 amp
21. Horn Relay 15 amp
22. Rear Wiper 20 amp
23. Rear Parking Light 10 amp
24. Open
25. ABS, Climate Control, Cooling Fan, Brake Switch 15 amp
26. Airbag control 10 amp
27. Airbag Control 10 amp
jeepngeorge is offline
Need fuse panel diagram SEMPER1GUMBY XJ Cherokee Technical Forum 1 02-20-2009 08:27 PM
1998 XJ Fuse Panel Diagram? coores14 XJ Cherokee Technical Forum 2 01-22-2008 01:09 PM
Fuse panel diagram nkeever XJ Cherokee Technical Forum 5 07-02-2007 05:53 PM
fuse panel Diagram 96 XJ hansgraf XJ Cherokee Technical Forum 2 10-24-2006 05:49 PM
"00 XJ Fuse Panel Diagram Mikepags XJ Cherokee Technical Forum 4 05-30-2006 10:03 PM
