96 Cherokee overheating - JeepForum.com
post #1 of 6 Old 01-18-2020, 06:36 PM Thread Starter
CoreyBritton
Ok I’m not very mechanically minded, I’ve taken my Jeep to two different shops for overheating issue, the first one replaced the water pump, and flushed the radiator, second one just flushed it out, both said it was good to go, and both times I drove it home “15 miles or so” didn’t run hot the next day it got close to the edge of the red, I replaced thermostat myself, same problem, I decided to take the thermostat out completely to see what happens, still does it, oil looks good, it runs good doesn’t run rough or anything, I’m thinking new radiator next, thoughts?
CoreyBritton is offline
post #2 of 6 Old 01-18-2020, 06:37 PM Thread Starter
CoreyBritton
Also it can idle for 20 minutes just fine it only gets to the red when driving it.
post #3 of 6 Old 01-18-2020, 10:29 PM
nathan915
nathan915's Avatar
How old is your lower radiator hose? If it's old and missing the inside spring the hose can collapse like a straw and cut off coolant flow. This usually happens at highway speeds when the system is under load.
nathan915 is offline
post #4 of 6 Old 01-19-2020, 08:48 AM
jtec
jtec's Avatar
2014 JK Wrangler
1996 - a change year often a surprise.
Do you have a serpentine accessory drive belt for engine?
Should be electric engine fan? - is it working?
jtec is offline
post #5 of 6 Old 01-19-2020, 10:24 AM
car6car
90% of mechanics are idiots. overheating problem was not diagnosed right from beginning.
you have to pay somebody for diagnosing, sometimes you have to pay dealer for 1 hour to diagnose a problem.
Infrared thermometer helps a lot ($25 from FarborFreight)
some problems are hard to diagnose, half clogged radiator for example.
04 Grand (dead)
car6car is offline
post #6 of 6 Old 01-20-2020, 03:53 PM
legendslayer
legendslayer's Avatar
Have you checked the fan clutch? Its pretty easy to check yourself, it can be a cheap part and easy to replace. and they go bad sometimes. Its the actuator for the engines main fan and radiator cooling from a spun coils temperature reading. And this is probably redundant but you've made sure the fluids and oil are topped and good oil flow and regular psi on the gauge? as in it goes up when you accelerate. Friction is the number one cause of heat
legendslayer is offline
