96 4.0 Engine into 99 XJ and a Few Other Questions - JeepForum.com
post #1 of 3 Old 05-12-2015, 09:34 AM Thread Starter
GoldCherokee
So it looks like the 206k 4.0 in my 99 XJ has finally decided to call it quits. It's got a hell of a tick (more like a banging sound) from the top half of the motor that I suspect is a completely collapsed lifter. While I know that this is somewhat fixable in the Jeep via head removal, the rest of the motor isn't in great shape. I also happen to have a complete 4.0 from a 96 XJ sitting on an engine stand in my garage, which was pulled running at 160k miles. Anyways, onto the questions;
1. Is there anything between the two years that wont match up? I plan to use the 96 long block with the 99 accessories. I think that should work, but I figured I'd ask to see if anyone knows about any major changes between the two motors.
2. The 96 4.0 has been sitting on an engine stand for almost 3.5 years. I had other intentions for it, but life got in the way, and things didn't happen. The engine ran great when it was pulled, but hasn't been turned over or messed with since. I'm pretty sure it still has the same oil in it from when I pulled it. What would you guys recommend I do before attempting to use it again? My thoughts were to replace most of the seals and make sure it turned over ok, but I didn't know if I should attempt to pull the head to check out the cylinders before messing with it. Everything I pull out will be put back together with new seals/parts if needed, but I would kinda like to keep the budget on this somewhat low.
3. Anything else that you guys would recommend doing while I've got it all apart?
Thanks in advance for any advice!
-Tom
1999 Cherokee 4.0 4WD
2005 Grand Cherokee 5.7 QDII Limited
GoldCherokee is offline
post #2 of 3 Old 05-12-2015, 04:44 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Any 1990-2001 XJ Cherokee or 1993-98 ZJ Grand Cherokee 4.0 L engine block will interchange.
Remove and re-use ( or replace with new ) as needed or required from your original engine: Intake/Exhaust manifolds, flex plate/flywheel, cylinder head, water pump, distributor-less ignition or distributor assembly, OBD engine sensors, fan belt driven accessories, and/or mounting brackets.
Spray some penetrating oil into each cylinder and crank the motor by hand. Replace the rear main seal, harmonic balancer, and the oil filter adapter seals. If it ran OK, leave the head on it.
CJ7-Tim is offline
post #3 of 3 Old 05-12-2015, 06:33 PM Thread Starter
GoldCherokee
Cool. That's what I thought I remembered, but it's been awhile since I've messed with Jeeps.
That's what I was leaning towards. Pulling the head seemed like too much work for what I need to do, but I didn't want to overlook anything.
Thanks for the reassurance!
-Tom
4.0 , engine , swap , xj
