89 XJ Renix Wireing diagram needed - JeepForum.com
post #1 of 9 Old 06-14-2019, 07:06 AM Thread Starter
YJ40
Hi,
im looking for a wireing diagram for a 894.0 with AT and (non HO) Renix fuel injection system. I would need the function of the connections to the injection Computer.
Thank you and sorry for my bad english...
Marcel.
89YJ 4.0l , my toy since 1999...
YJ40 is offline
post #2 of 9 Old 06-14-2019, 09:18 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
This help?
And, if you want to share the issues you're having, we can help. Also be sure to visit www.cruiser54.com
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 9 Old 06-15-2019, 08:36 AM Thread Starter
YJ40
Hi, and thanks for the help.
I installed this 4.0 non HO (it came with an AT) 18years ago in my YJ with broken 2.5l.
From the beginning i had a problem, idle is 800-1300+ 1/min, but not constant...
There are no vacuum leaks,no problems with throttlelinkage. I changed and tested TPS and IAC without success.
One thing is that the injection computer needs a speedsignal,or better no speed signal ,this pin i mounted to vehicle ground , but nothing changed.
The other thing could be that it needs the information about the AT neutral position (i have a AX15) but i can't find this in the wireing diagram...
Last thing that rises rpm is an AC request (AC is out of order and works as an onboardair compressor).
So thats my problem but it's not a big problem so from time to time i try to solve it...now it's time again...
Marcel.
YJ40 is offline
post #4 of 9 Old 06-15-2019, 10:57 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The Renix ECU doesn't care what gear the vehicle is in.
Have you been to my website and adjusted the TPS properly?
checked the sensor ground circuit per Tip 5?
post #5 of 9 Old 06-15-2019, 12:06 PM Thread Starter
YJ40
I've been on yor website,great instructions. Will check it tomorrow...
YJ40 is offline
post #6 of 9 Old 06-16-2019, 07:30 PM
Que89YJ
What about your egr valve?
Sent from my SM-G955U using Tapatalk
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #7 of 9 Old 06-17-2019, 03:22 PM
Sam-daily
Sam-daily's Avatar
You can buy the FSM
http://www.pacificcoastmanuals.com/j...e_manuals.html
Aslo, cruiser54's tips and tricks are invaluable. Check out his page. Wouldent hurt to run through everything there for good mesure.
Good luck.
Sam-daily is offline
post #8 of 9 Old 06-21-2019, 10:16 AM Thread Starter
YJ40
Hi,
checked sensor ground, it was okay. TPS was not properly adjusted, but i think it was as it was installed new. Had no time for a testdrive, maybe weekend...
EGR valve is completely blocked.
Thanks !
YJ40 is offline
post #9 of 9 Old 06-24-2019, 12:26 PM
Que89YJ
Update?
Fault codes:
No Start:
Que89YJ is offline
