89 renix HP steering hose replacement tips - JeepForum.com
post #1 of 8 Old 08-21-2016, 09:14 AM Thread Starter
ainetsc
So the high pressure hose on my power steering sprung a leak, any tips/ write ups for replacement - it looks tight down there and what fluid is recommended.
Thanks for any info.
ainetsc is offline
post #2 of 8 Old 08-22-2016, 05:22 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Remove the electric fan assembly for much more working room.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 8 Old 08-23-2016, 01:01 PM Thread Starter
ainetsc
Thanks, what fluid would you use the service manual mentions Dexron 11
ainetsc is offline
post #4 of 8 Old 08-23-2016, 03:29 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That's fine, but you'll only find Dex/merc III any more. Same as used in your automatic trans.
post #5 of 8 Old 08-24-2016, 02:17 PM Thread Starter
ainetsc
Ok got it - so regular power steering fluid will not do it?
ainetsc is offline
post #6 of 8 Old 08-24-2016, 05:44 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Either one is fine.
post #7 of 8 Old 08-25-2016, 07:43 PM Thread Starter
ainetsc
Thanks, not the easiest of jobs but back on the road now, had to cut the pipe and worked a 18mm spanner from the chassis side to loosen it up, removing the fan definitely helped. not easy to get back in one hand holding the lower rad hose and the other getting the pipe in.
Thanks for your help.
ainetsc is offline
post #8 of 8 Old 08-25-2016, 09:45 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Great job. Thanks for the update.
power steering hose , renix , replacement
