89 renix HP steering hose replacement tips
So the high pressure hose on my power steering sprung a leak, any tips/ write ups for replacement - it looks tight down there and what fluid is recommended.
Thanks for any info. |
Remove the electric fan assembly for much more working room.
Thanks, what fluid would you use the service manual mentions Dexron 11
Ok got it - so regular power steering fluid will not do it?
Thanks, not the easiest of jobs but back on the road now, had to cut the pipe and worked a 18mm spanner from the chassis side to loosen it up, removing the fan definitely helped. not easy to get back in one hand holding the lower rad hose and the other getting the pipe in.
Thanks for your help. |
Great job. Thanks for the update.
The time now is 01:18 PM. |
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by
Advanced User Tagging (Pro) -
vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by
vBSecurity v2.2.2 (Pro) -
