89 remix skip/exhaust backfire - JeepForum.com
post #1 of 5 Old 03-06-2016, 09:54 PM Thread Starter
goatworks88
Hello all and thanks in advance.
traded my motorcycle for this cherokee a few months ago and I've been trying to get it running well since. Someone needs their tools thrown away due to some of the wiring repairs that I have had to go and re-fix. But to my actual problem.
Starts up fine, idles fine, but when you accelerate from a stop under normal load it starts bucking and backfiring. The previous owner gutted the cat and swapped out a few injectors chasing the problem, which I found out about later. So I have spent the last months cleaning wires and changing injectors. To no avail.
Still skipping and bucking and backfiring. You can power through it and it runs fine. Until you get to causing speed of about 55 and start to cruse then it starts up again.
I have adjusted the distributor, adjusted tps, replaced the o2 sensor due to being stuck at 2 volts, replaced old worn plugs and wires, checked compression (135-140), the only thing that I have not done is check fuel pressure and replaced cps.
Any help or insite on this problem. Oh and my wife would thank you also. She now hates the jeep and me sometimes because of it. Lol
Thanks.
Sent from my SM-T320 using Tapatalk
goatworks88 is offline
post #2 of 5 Old 08-23-2016, 12:10 AM
john3416
1989 XJ Cherokee
Same issue
I have been fighting this with my 89 for a while after installing a newly rebuilt engine. Saturday, after completing much of what you have done, changed throttle control with newer TPS and IAC , changed the EGR control valve, ballast resister, #3 spark plug and the distributor and finally no back fires and it runs fine. The only issue I have now, trany shifting issues. It does not like to upshift. I tried adjusting the kickdown but no avail.
john3416 is offline
post #3 of 5 Old 08-23-2016, 09:17 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Thanks.
I would begin here:
http://cruiser54.com/?p=19
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #4 of 5 Old 08-23-2016, 09:19 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
That isn't a kickdown cable. It's a throttle valve cable. It increases the line pressure in the trans as the throttle is opened further.
Could be the trans side of the TPS is bad.
Before I went there I would do this:
http://cruiser54.com/?p=19 and this:http://cruiser54.com/?p=58
post #5 of 5 Old 08-25-2016, 09:12 AM Thread Starter
goatworks88
Figured it out. It is a streched timing chain and a distributor out of time.
Sent from my SM-G900P using Tapatalk
