4.88 gears in 8.25 and the 35 - JeepForum.com
post #1 of 11 Old 10-06-2010, 07:02 PM Thread Starter
CherokeeTim
1997 XJ Cherokee
anyone who did this did you just need to order just the ring a pinion kit or did you need a hole new housing for the gears too?
CherokeeTim is offline
post #2 of 11 Old 10-06-2010, 07:04 PM
the_weirdo
the_weirdo's Avatar
When you say "housing for the gears" do you mean the carrier which the gears mount to or are you asking about the actual axle housing itself?
the_weirdo is offline
post #3 of 11 Old 10-06-2010, 07:06 PM Thread Starter
CherokeeTim
1997 XJ Cherokee
i mean the carrier for the gears
post #4 of 11 Old 10-06-2010, 07:11 PM
LIsurfcasters
assumming that you had stock gears, then yes for the 4.88 gears you would need to upgrade to a carrier that will fit that gear range.
LIsurfcasters is offline
post #5 of 11 Old 10-06-2010, 07:14 PM
the_weirdo
the_weirdo's Avatar
You do not need a new carrier for 4.88 gears in a C8.25. The carrier break is super low - like near 2.56 or something. No need to worry about it on XJs.
Ring Gear Diameter: 8.25"
Cover Bolts: 10
Carrier Breaks: 2.45 / 2.56
Max Recommended Tire Size: 33
Edit: go do a google search for "carrier break 8.25 chrysler" and you will see plenty of pages that say the carrier break is non-existent for XJs (because our gears are numerically too high)
post #6 of 11 Old 10-06-2010, 07:47 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You need the ring and pinion set, a complete install kit with bearing and shims, and the know how to set-up the gears along with a few special tools. Or someone who knows how to set them up for you.
xjfever is offline
post #7 of 11 Old 10-06-2010, 07:49 PM Thread Starter
CherokeeTim
1997 XJ Cherokee
you say i don't need it for the 8.25 but what about the dana 35?
post #8 of 11 Old 10-06-2010, 07:50 PM Thread Starter
CherokeeTim
1997 XJ Cherokee
yeah i was gonna have a place do my gears because i don't know anything about that
post #9 of 11 Old 10-06-2010, 08:30 PM
the_weirdo
the_weirdo's Avatar
In a Dana 35, the carrier break should be 3.55 and higher use the same carrier. If you have 3.55 or higher gears, there is no need to change carriers. If you have the 3.07 gears (manual) you will need a new carrier.
Edit: confirmed here: http://www.quadratecforum.com/showpost.php?p=863578
2nd edit: As someone who has regeared a Dana 35 rear axle and wasted the money...Don't waste the money. Find another rear axle (C8.25, D44, or Ford 8.8) and regear it.
post #10 of 11 Old 10-07-2010, 03:52 AM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
Good advice, though I might add that a LATE MODEL 8.25 (29 spline) is the one to look for if going that route. I don't think an early 27 spline would be worth the effort.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #11 of 11 Old 10-07-2010, 04:54 AM Thread Starter
CherokeeTim
1997 XJ Cherokee
my rear axle is the late model 8.25, i'm just one step ahead of you guys and you didn't even know it
new gears and broken gears. bikedude189 XJ Cherokee Technical Forum 6 08-19-2009 05:34 PM
need new gears mattgrant11 MJ Comanche Technical Forum 1 07-17-2009 11:09 PM
Gears???? XscottJ XJ Cherokee Technical Forum 1 05-05-2009 07:08 PM
**** Gears Vs. Motive Gears. Cherokeekid88 XJ/MJ Cherokee Non-Technical Forum 6 03-28-2009 09:35 PM
Standard Gears vs Thick Gears godplayer XJ Cherokee Technical Forum 5 04-11-2006 09:58 PM
