4.0 XJ wont start or Idle by itself without the accelerator pressed when cold - JeepForum.com
post #1 of 10 Old 01-16-2008, 02:24 AM Thread Starter
L20KEV
Guest
I have a 1998 4.0 Xj and yesterday it would not start with out the gas and when it did it would instantly die unless you keep the gas on. after 5mins it idles/drives perfectly and is fine until it gets cold again.
Any suggestions?
the only other thing it has problem wise, is the cat box has rattled inside for the last 6 months. The check light, light is fine.
L20KEV is offline
post #2 of 10 Old 01-16-2008, 08:50 AM
NYCXJ90
NYCXJ90's Avatar
2014 JK Wrangler
check the fuel filter, could be slightly blocked. Check the linkages on the TB, clean the IAC.
'90 XJ Laredo RE 3.5" Super Ride
'95 ZJ 5.9 Stock
NYPD Jeep Club Member #2
Marine Corps Jeep Club Member #3
So I tell the swampdonkey to sock it before I give her a trunky in the tradesman's entrance and I have her lick me yardballs.
NYCXJ90 is offline
post #3 of 10 Old 01-16-2008, 10:06 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Have the battery load tested at a shop or auto parts store. You have the classic symptoms of a bad battery or corroded battery connections. When the battery goes dead or when one of the cells goes bad and you have reduced voltage, the engine computer forgets the idle settings. After 3-8 minutes of running or driving, the idle settings are re-learned. Your battery may have enough power to start the engine but the computer is sensitive to low voltage.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #4 of 10 Old 01-16-2008, 10:16 AM
CharBroiled
Guest
this is from the fsm on my 2000, but 98 should be about the same.
the computer is rated for 8 volts and will lengthen the injector pulse to compensate for low voltage (it monitors battery voltage for this purpose). in theory it should run fine till it drops below 8 volts. also when cold (open loop mode) it ignores learned idle settings and uses hard coded preset values. once its warmed up it will use the learned settings.
sounds like the cat or IAC maybe.
CharBroiled is offline
post #5 of 10 Old 01-16-2008, 11:26 AM Thread Starter
L20KEV
Guest
Thanks for all your advices
whats the IAC?
As the cat is rattling i wonder if a part has broken off inside and part blocking it? could this cause it?
If i was to replace the CAT would i need to replace the o2 sensor or are they generally ok?
Last but not least is there away with checking the fault codes on mine (something to do with the dash milometer flashing etc?
L20KEV is offline
post #6 of 10 Old 01-16-2008, 11:39 AM
CharBroiled
Guest
IAC = idle air controller.. it sets idle speed.
it may be when the cats cold its blocked a bit but when it warms up it expands a little and unblocks a bit. but even if the cats not the problem if it rattles you need a new one anyway. not sure about reusing the o2 sensor.
pretty sure for a 98 you need an OBDII code reader.
post #7 of 10 Old 01-16-2008, 12:14 PM
Mtb Jak
Mtb Jak's Avatar
had that problem.. put a new battery in and bang fires up great now!
had to rev the engine a bit on cold starts right from the turnover.. was not good.
Mtb Jak is offline
post #8 of 10 Old 01-16-2008, 07:20 PM
RBxj
Check your local dealer on the cat issue, they had a recall on certain years just for that problem, got the one on my 96 replaced for free.
RB
RBxj is offline
post #9 of 10 Old 01-18-2008, 02:05 AM Thread Starter
L20KEV
Guest
does the recall have an expiry date? is there a list of what was recalled anywhere?
thanks
L20KEV is offline
post #10 of 10 Old 11-05-2011, 08:13 PM
autoposer
Same solution
My battery was only 12 months old, but was causing the same symptoms and once replaced fixed the issues. I tried cleaning the idle control valve and throttle body first. Even though it didn't fix the issue it now idles like it did 12 years ago despite have 170K miles on it. Highly recommend cleaning the IAC regardless.
autoposer is offline
wont start when cold 70Eliminator XJ Cherokee Technical Forum 6 01-29-2010 01:45 AM
98 will only start when gas is pressed. Zero idle broncofire75 XJ Cherokee Technical Forum 6 10-23-2009 02:33 PM
Cold start, low idle, IAC ok... HeVGunner XJ Cherokee Technical Forum 8 02-11-2008 01:23 PM
Jeep wont start in cold!! vertastang XJ Cherokee Technical Forum 4 01-10-2006 07:52 AM
Won't start unless pedal is pressed, non-existent idle, must feather throttle goriath XJ Cherokee Technical Forum 7 08-31-2005 09:17 AM
