4.0 engine compatibility - Page 10 - JeepForum.com
 1Likes
post #136 of 146 Old 01-02-2019, 09:03 AM
jjstrom
jjstrom's Avatar
Originally Posted by ZEN357 View Post
All Comes down to budget, and those options are out of my budget.
Originally Posted by 75SV1 View Post
I think the intake would be the same. If it looks like the present one. The latter intake is a bit larger and rounded on the corners. It can be an upgrade. Either way, you can just swap on your fuel rail.
Thanks I was thinking that I should be able to swap just the rail but wasn't sure.
Originally Posted by CJ7-Tim View Post
Remove and re-use as needed or required from your original engine: Fuel Injector rail, Intake/Exhaust manifolds, flex plate/flywheel, cylinder head, distributor-less ignition or distributor assembly, engine sensors, motor mounts, fan belt driven accessories and/or mounting brackets.
Thank you, I know about the reuse of various parts as need. I just wasn't sure if I could just swap the fuel rail.
If you need me I'll be working on my Jeep.
jjstrom is offline
post #137 of 146 Old 01-03-2019, 09:48 AM
ZEN357
I can understand the budget issue. We all have other things we gotta pay for. Just sucks you can't put a newly rebuilt engine in it. Good luck!!!!
ZEN357 is offline
post #138 of 146 Old 01-04-2019, 10:10 PM
TomJeep21
Originally Posted by cruiser54 View Post
XJ Cherokee and ZJ Grand Cherokee 4.0L engine blocks interchange.
2000+ TJ Wrangler and WJ Grand Cherokee 4.0L engine blocks interchange.
XJ/ZJ blocks and 2000+ TJ/WJ blocks do not interchange without significant modifications. (1997-1999 4.0L TJ Wrangler blocks will interchange in XJ/ZJ and visa-versa).
TJ/WJ 4.0L Engine blocks underwent clean sheet design changes effective in the 1999 WJ Grand and 2000 TJ Wrangler. These blocks are not interchangeable with XJ/ZJ engine blocks. The reason is motor mount bolt holes and belt driven accessory mounting bolt holes are in different locations, or not present at all, TJ/WJ vs. XJ/ZJ.
I hope it's not to late for me but I bought a 2000 xj with the 32rh and I have a 2000 TJ with the NV3550. I wanted to swap the xj 4.0 with the harness and all the accessories into the TJ with the NV3550. If im reading this right I would run into issues if I wanted to take the xj block and use all the TJ accessories. But what I'm not sure is if I'm going to run into issues using the xj engine because of the motor mounts. I do have the manual pcm, cps, manual trans, flywheel. Both engines are a coil pack setup.
Will this work?
TomJeep21 is offline
post #139 of 146 Old 01-05-2019, 08:21 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by TomJeep21 View Post
.... swap the xj 4.0 with the harness and all the accessories into the TJ with the NV3550. If im reading this right I would run into issues if I wanted to take the xj block and use all the TJ accessories. But what I'm not sure is if I'm going to run into issues using the xj engine because of the motor mounts.
Will this work?
Too much effort for no benefit.
The XJ engine block will not bolt in, and the XJ block belt driven accessories are in the wrong physical locations for all the TJ wire connections and A/C connections. The TJ block belt driven accessories brackets will not bolt onto the XJ block.
The XJ has an AW-4 automatic transmission.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #140 of 146 Old 02-08-2019, 01:49 PM
Submariner
Submariner's Avatar
I know this has been answered but I will ask anyway.
I have a 99 Cherokee 4.0 with way to many miles, 250K, on it and it needs replacing. I have a 89 4.0 with only 167K on it. can the "blocks" be swapped?
I intend to replace the oil pump and the crank seals and oil pan gasket for the block. I will also check the timing chain to see how loose it is. I already know that there is not much wear on the cylinders. no piston sloop.
I will be using the 99 head, it is good so far.
Questions that need to be checked on,
Pushrods, use the 99's or 89's?
Cam and Lifters should be good but how do I check them to make sure they are ok?
Any other things I should do to it while I have the engine out of the truck?
Submariner
Submariner is offline
post #141 of 146 Old 02-21-2019, 02:09 PM
Jabin Trapp
2002 TJ 4.0 engine block into a 95 TJ
I have a 02 TJ engine that my friend wants to put in his 95 YJ.... I have read the forums and dont see this direction? friend will retain all accessory and intake... just short block and hopefully head. Will the newer TJ block go into older YJ?
Jabin Trapp is offline
post #142 of 146 Old 02-21-2019, 04:07 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
XJ/ZJ blocks, and the 2000+ TJ/WJ blocks DO NOT interchange without significant modifications. (1991 to 1995 YJ and 1997-1999 4.0L TJ Wrangler blocks will interchange in XJ/ZJ and visa-versa).
XJ: "Regular" (not Grand) Cherokees 84-01
ZJ: Grand Cherokee 93-98 (Gen1)
WJ: Grand Cherokee 99-04 (Gen2)
YJ: Wrangler 87-95 (Gen1)
TJ: Wrangler 97-06 (Gen2)
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #143 of 146 Old 03-30-2019, 08:10 PM
ChrisR2000XJ
And here's an updated version:
XJ/ZJ blocks and 2000+ TJ/WJ blocks do not interchange without significant modifications. (1991 to 1995 YJ and 1997-1999 4.0L TJ Wrangler blocks will interchange in XJ/ZJ and visa-versa).
Hi
I have a 2000 XJ 4.0 That needs a new engine. I read somewhere that I could use an replacement short block for my year jeep, but that the heads off a newer wrangler would work/ bolt up and actually hold up better and were stronger.
Is this accurate information ??
Thanks - Chris R
ChrisR2000XJ is offline
post #144 of 146 Old 04-01-2019, 09:25 AM
CJ7-Tim
CJ7-Tim's Avatar
Originally Posted by ChrisR2000XJ View Post
Hi
Thanks - Chris R
If your 2000-2001 XJ Cherokee has a cracked 0331 head, buy a good used redesigned and more durable TUPY 0331 head from a 2002+ 4.0L TJ Wrangler or WJ Grand Cherokee.
- Benjamin Franklin
CJ7-Tim is offline
post #145 of 146 Old 08-25-2019, 12:53 PM
macjeep01
jeep wrangler engine
does anyone know if a 2005 jeep grand cherokee laredo v6 will fit in 2001 jeep TJ wrangler?
JOhn
macjeep01 is offline
post #146 of 146 Old 08-25-2019, 07:07 PM
Jeepsr4me
JOhn
Heck ya it will fit...
You might want to read a little more on engine compatibility before asking if something will fit. I can put 5 33inch tires inside the jeep.... Is that were they go, not really. Same goes for that turd of a v6 the one that comes in the 05 GC.
Find you a 99-04 GC and that engine will fit perfectly... I have done that install many times.... many... Its my go to for engines for the 2000 and up Wrangler.
Thing is also that most pull a parts are full of GCs and most driven easy. I have pulled just this year 3 at pull a part and cost just 175 plus ANY core.. They aint into rebuilding just scrap metal.. I get the engine complete with all accessories and return it with nothing but block.. sell off all those goodies on ebay and make my money back
Jeepsr4me is offline
cherokee , compatibility , engine
Engine Compatibility bullydad XJ Cherokee Technical Forum 2 03-03-2012 10:28 AM
Engine Compatibility stinealbert XJ Cherokee Technical Forum 1 12-14-2011 01:20 AM
engine compatibility nhlnms XJ Cherokee Technical Forum 12 06-16-2010 02:55 PM
2.5 engine compatibility 01xjltd MJ Comanche Technical Forum 1 04-03-2010 10:01 PM
Engine compatibility Lkhoyt XJ Cherokee Technical Forum 9 06-08-2007 10:49 AM
