LinkBack | Thread Tools |
242J vs. 242J Police / Export
I'm doing a transfer case swap & my 2001 Sport, it has a 231J. I'm taking the 231J out & I have a 242J. I believe the 242J I have is a Police / Export transfer case. I'm trying to figure out if I actually have a 242J Police / Export transfer case.
How do I know if I have a normal 242J or a 242J Police / Export model???
Sponsored Links | |||
What's the difference?
Real Jeeps have dents
5211 1083 is the part number.
CJ7-Tim, thank you very much.
I'm wondering about the same thing.. what's the difference between the two?
***Under construction***
Allpar gives an overview-
http://www.allpar.com/squads/police-cars/cherokee.html
Part number shows that chain may no longer be available-
http://www.factorychryslerparts.com/.../04638890.html
I suspect that chain may be heavier and wider....gears also.....may want to check for future availability before installing.
I assumed the chain is stronger. I don't understand how one tooth design is better than another with this set up......
https://www.novak-adapt.com/catalog/..._242_parts.htm
I thought I saw a website some where that the planetary gears were stronger, but I might be confusing that with a 242-HD. In fact, I was under the impression the Police / Export was a Heavy Duty version. But, I believe I am mistaken with that assumption.
Can I also assume all XJ's sent to Canada with a 242J fall into the "Export" category?
Was the "Police Package" an attemp to use extra Mopar stock & charge a higher price for a 242 transfer case package???
Originally Posted by MaskedMallard
View Post
http://www.novak-adapt.com/catalog/t..._242_parts.htm
Round Pin vs. Rocker Joint
http://www.atraonline.com/gears/1997.../gaug97p69.htm
From what I gather, the Rocker Joint is more efficient. The Rocker Joint is apparently found in the Police / Export XJ package of the 242J transfer case.
Heavy duty transfer cases use a wider chain. Both chain styles have been used on the NP/NV transfer cases (round pin and rocker joint), but none of the heavy duty cases have a narrow chain. I've never seen an XJ with a wide chain, but I've seen both chain styles.
My both previous XJs were export models with a 242, and my niner is a ZG built in Graz, Austria. ZJ had a wide chain in it's 249, both XJs had a narrow chain. All using rocker joint design.
Previous Thread
Next Thread
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Posting Rules | |
