242 noise - JeepForum.com
post #1 of 8 Old 06-06-2020, 10:04 PM Thread Starter
chris79
JK Wrangler
242 noise
Need some help. When in 4wd under load when I push the gas I get a horrible grinding noise that sounds like it’s coming from under the 4wd shifter, so by the front output shaft/yoke. Drained the fluid and it was perfectly clean and full. Took the front shaft off and drove it in 4wd and no noise at all. Do bad shafts/u joints ever make that sort of sound? Could it be the front output bearing only making a noise with the shaft in under load? Oh and it’s a 98. Thanks in advance for the help.
chris79 is offline
post #2 of 8 Old 06-07-2020, 05:10 AM
kadetklapp
kadetklapp's Avatar
1997 XJ Cherokee
I’ve got this with my 231 only when I drained the fluid chunks of what I suspect is sprocket came out. Only in high though. Never in low.
**1997 Jeep Cherokee SE**
Former Police Car assigned to 54-26, RIP.
kadetklapp is offline
post #3 of 8 Old 06-07-2020, 05:21 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by chris79 View Post
When in 4wd under load when I push the gas I get a horrible grinding noise ....
4wd Hi, 4wd Lo, or both ? U-joints that bad would be really obviously loose.
A slower and low pitched kind of bang, bang, bang, or a higher pitched really fast grrrrrrrrrrrrrrr ?
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #4 of 8 Old 06-07-2020, 07:54 AM Thread Starter
chris79
JK Wrangler
No bang or anything, just a grinding under load in 4hi and full time that I’ve tried. The u joints on the shaft ‘seem’ fine? There isn’t any play in the front yoke and it seems to turn by hand easy.
chris79 is offline
post #5 of 8 Old 06-07-2020, 10:12 AM
CJ7-Tim
CJ7-Tim's Avatar
Are you a new XJ Cherokee owner ? The XJ Cherokee 231 and 242 transfer cases make a noticeable whirring sound in 4x4.
- Benjamin Franklin
CJ7-Tim is offline
post #6 of 8 Old 06-07-2020, 11:54 AM Thread Starter
chris79
JK Wrangler
I’ve owned 4 XJs and 2 TJs, I know that all make a bit of noise in 4wd. Trust me, this noise is not normal.
chris79 is offline
post #7 of 8 Old 06-07-2020, 12:13 PM
kadetklapp
kadetklapp's Avatar
1997 XJ Cherokee
Is it like a high pitch, sudden fast grinding? That’s what mine does..
post #8 of 8 Old 06-07-2020, 12:18 PM Thread Starter
chris79
JK Wrangler
It’s a grind under load, gets higher with higher speed
chris79 is offline
