2000 XJ Rear axlw !!!! which one - JeepForum.com
post #1 of 14 Old 05-29-2020, 09:26 AM Thread Starter
Hamid
Hamid's Avatar
Hello everyone:
My XJ is 2000 year model 4WD (AW4), select track NP242, frond axle is Dona 30. It is built for export.
VIN: 1J4FFB8V9YL194116
Tomorrow I will remove my rear axle ( Dana 35 ) and will install another rear axle ( flat bottom ), which seems to be the Chrysler 8.25,,,, because the old axle has some friction noise on turns and slips on reverse. Till then I hope for some answers to my questions,,,,,,,to save time much as profit.
1- How do I know what rear axle was installed when this XJ came out from the plant?.
2- What is the common rear axle used on 2000 XJ?.
3- I heared that both front and rear axles ratios must be the same, is it true?
Thanks for the advise.
2000 Jeep Cherokee Classic. Built for export
432K Kilos.
Hamid is offline
post #2 of 14 Old 05-29-2020, 11:04 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
1) Request a "Build Sheet" from Chrysler Jeep website.
2) Both Dana 35 and Chrysler 8.25 axles were installed on 1997-2001 Cherokees. If Jeep has ABS and you want to keep ABS, you need a Dana 35 with ABS. No Cherokee Chrysler 8.25 ever had ABS.
3) Axle ratio for 4x4's must match within 2%, 3.54 - 3.55 is OK.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #3 of 14 Old 05-29-2020, 12:53 PM
Ralph77
Assuming the build sheet is right it is a D35.
https://fcacommunity.force.com/RAM/s/equipment-listing
Ralph77 is online now
post #4 of 14 Old 05-29-2020, 01:57 PM Thread Starter
Hamid
Hamid's Avatar
Thanks CJ7-Tim, my XJ is non ABS and non Cruise control, so 8.25 is good pic.
Thanks Ralph 77, that what is installed now,maybe the original.
432K Kilos.
Hamid is offline
post #5 of 14 Old 05-29-2020, 05:23 PM
Devil15
Also look for an 8.25 with limited slip. Theres a sticker in the glove box that will let you know it's a limited slip. When my d35 blew up I had to pick through about 20 cherokees before I found one but it bolted right in all I needed to change was the ubolts.
Sent from my SM-G892U using Tapatalk
Devil15 is offline
post #6 of 14 Old 06-03-2020, 04:23 PM
PimaXJ
1997 XJ Cherokee
@CJ7-Tim , I feel as if I am on thin ice here as you are always accurate & truly a fount of information but the 8.25 found in the KJ Liberty came with the 8.25 with ABS did it not?
PimaXJ is offline
post #7 of 14 Old 06-03-2020, 05:01 PM
CJ7-Tim
CJ7-Tim's Avatar
ABS was a option on a KJ Liberty until 2006 when it became standard due to ESP, but neither the KJ axle nor the ABS will bolt onto an XJ without significant modifications.
- Benjamin Franklin
CJ7-Tim is offline
post #8 of 14 Old 06-04-2020, 01:23 AM Thread Starter
Hamid
Hamid's Avatar
Hi everyone:
Went to a friend's shop, he removed the Dana 35 ( Dana 35C, C-clip – 3.07 ratio (43-14) it is OEM as in the build sheet thanks to Ralph77, installed used low milage 8.25 with hubs, shoes, serviced, hand brake adjusted, rear drive shaft UJ replaced with new ones, went for test, results:
1- No whining sounds at all speeds ( Dana 35 has sounds and it jerks on turns ).
2- Vibrations reduced to nearly 95% (used ti vib over 110 KMH).
3- Speedometer difference now 4 KMH ( was 15 KMH ). wish I know ho to correct that to zero diff.
That was very good swap to me, 8.25 has locking feature, which Dana 35 did not.
For the ABS, the mechanic didn't mention any thing about it and I did not bother to ask too.
432K Kilos.
Hamid is offline
post #9 of 14 Old 06-06-2020, 06:05 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Are your axle ratios the same back and front?
You can change the ratio with a new ring and pinion,
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #10 of 14 Old 06-06-2020, 09:29 PM Thread Starter
Hamid
Hamid's Avatar
I don't know, the mechanic said the 8.25 rear axle he put on has a 39/(?) pinion and it is the same for the front axle.
(Axle ratio for 4x4's must match within 2%, 3.54 - 3.55 is OK.) that's CJ-17 reply in post#2.
432K Kilos.
Hamid is offline
post #11 of 14 Old 06-07-2020, 08:33 PM
Mrtoyou
Mrtoyou's Avatar
The fact that your speedo is reading different after the rear end change is a clue that your gear ratio is not the same as before. DO NOT shift into 4WD until you physically verify the gear ratio is the same in the front and rear within 2%!!!!!
If I have to explain it, you probably won't understand anyway!
Mrtoyou is offline
post #12 of 14 Old 06-08-2020, 04:56 AM
CJ7-Tim
CJ7-Tim's Avatar
Originally Posted by Mrtoyou View Post
The fact that your speedo is reading different after the rear end change ..... ....
Every XJ Cherokee Speedometer left the Jeep factory displaying about 1%-3% error. Manufacturing tolerances and air pressure can cause tire diameters to vary, which may lead to additional speedometer errors.
- Benjamin Franklin
CJ7-Tim is offline
post #13 of 14 Old 06-08-2020, 06:50 AM
MaskedMallard
Originally Posted by Hamid View Post
Hello everyone:
Hi everyone:
Based on your build sheet, assuming it's correct, you have the "UpCountry" package. That could explain your noise, due to the Trac-Loc 3:55 ratio failing.
I'm a little confused about you mentioning you have a Dana 35C, C-clip - 3.07 ratio.
Do you know the gear ratio of the C8.25 rear axle that was just installed into your XJ?
2001 BJC Orvis XJ Build -
MaskedMallard is offline
post #14 of 14 Old 06-08-2020, 10:52 AM
Mrtoyou
Mrtoyou's Avatar
"3- Speedometer difference now 4 KMH ( was 15 KMH ). wish I know ho to correct that to zero diff."
That is NOT a 1%-3% difference, that is a different gear ratio.
Mrtoyou is offline
