2000 XJ only 125 compression - JeepForum.com
post #1 of 5 Old 05-07-2021, 03:32 PM Thread Starter
Wyo
Wyo's Avatar
so I did a compression check of my 2000 XJ 4.0
5 strokes
all plugs out
Throttle open
Cold
180K Miles
pretty even between 120 + - 125 or so...
How bad is this?
Wyo is offline
post #2 of 5 Old 05-08-2021, 08:26 AM
BagusJeep
BagusJeep's Avatar
1981 CJ7
Spec is 120 to 150 psi so your engine is still in spec and will run.
At that mileage it is probbaly rings starting to wear but could also be valves leaking a little.
I would drive it.
BagusJeep lives in Bali with far too many 4x4s:
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
1980 Land Rover Series III 109" troop carrier - ROVER
BagusJeep is offline
post #3 of 5 Old 05-08-2021, 09:10 AM
Fourspeedman
Fourspeedman's Avatar
It is not so much the amount of compression, but rather the difference between cylinders. If they are all that close, then all is well. As the engine warms up and the pistons expand the compression should bump up.
Mark in Queens- Home of Spiderman and the Ramones
Fourspeedman is offline
post #4 of 5 Old 05-08-2021, 06:17 PM
axlaxl
120-125 cold across all pistons sounds OK.
axlaxl is offline
post #5 of 5 Old 05-08-2021, 08:31 PM Thread Starter
Wyo
Wyo's Avatar
Thank you all very much for letting me know..... I was very concerned.
Wyo is offline
