2000 XJ chip key issues - JeepForum.com
 1Likes
  • 1 Post By jtec
post #1 of 9 Old 12-11-2019, 05:18 PM Thread Starter
camorris1
Question 2000 XJ chip key issues
I hope someone can help me, the dealerships I've called surely can't. I recently purchased a 2000 XJ, 4.0L, auto and NP242 select trac for my son. The issue is it only came with one key. I called several dealerships and the local one uses a local locksmith for chip style keys. I went to the locksmith who cut a key but when they tried to program it said that their two machines could not communicate with the vehicle computer so it must be bad. Trying to verify/narrow the possibilities, I called the dealership service center who only wanted to sell me a key, etc. Has anyone had or seen this? What's my next step? The XJ runs great, no other issues. I just want to get a spare key before my "teenager" loses the only one. Thanks for any help/suggestions.
camorris1 is offline
post #2 of 9 Old 12-11-2019, 06:22 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Is the chip-in key SKIM anti-theft a valuable feature you want to keep, and how much do you want to spend for special keys and key programming and possibly a new PCM with Dealership PCM programming ? It is unlikely that the PCM is faulty if the SKIM system functions, and the Jeep runs.
The SKIM anti-theft system is somewhat prone to failure which requires a refurbished or new replacement PCM, and Dealership PCM programming.
I would buy a good used PCM and delete the SKIM anti-theft system. Then you can use normal keys. This is the lowest cost solution even if you install an aftermarket alarm system.
CJ7-Tim is offline
post #3 of 9 Old 12-11-2019, 09:59 PM Thread Starter
camorris1
"I would buy a good used PCM and delete the SKIM anti-theft system."
How would one delete the SKIM system? Is that something I can do? Can I delete the SKIM from my current PCM?
post #4 of 9 Old 12-12-2019, 04:11 AM
MaskedMallard
Xj
You might be able to take the SKIM key & tape / glue it to the inside of the steering column, as close to the ignition lock cylinder as possible. Then you should be able to start the Jeep with a non-SKIM key.
2001 BJC Orvis XJ Build -
MaskedMallard is offline
post #5 of 9 Old 12-12-2019, 05:30 AM
CJ7-Tim
CJ7-Tim's Avatar
To delete the SKIM anti-theft system you need a good either used or refurbished PCM that does not have the optional SKIM functions enabled. You then unplug and remove the chip in key reader device, install your "new" PCM and the job is done.
Originally Posted by MaskedMallard View Post
…. take the SKIM key & tape / glue it to the inside of the steering column, as close to the ignition lock cylinder as possible. Then you should be able to start the Jeep with a non-SKIM key.
This will work, but gives me two worries. The SKIM system is still, in my opinion, susceptible to failure that might leave you stranded, and secondly should a thief be trying to steal the Jeep, they will likely find the key and drive off.
CJ7-Tim is offline
post #6 of 9 Old 12-12-2019, 05:46 AM
Camaro45th
So....I have a question. I too have recently purchased a 2000 XJ Auto. Came with one key and one remote.
I went to HD and just made a copy of the key for like $5 and it works fine. I donít have a chip in my key. Are you sure yours does?
Camaro45th is offline
post #7 of 9 Old 12-12-2019, 07:34 AM
jtec
jtec's Avatar
2014 JK Wrangler
Before reinventing the wheel -
WHY can the system not communicate?
Could there be a simple issue at DLC?
When starting the jeep - does the CEL come on @ 3seconds every start?
Confirm 12v at cavity 16 of DLC (common issue) ?
PS - SKIM was a factory OPTION in 2000
Camaro45th likes this.
jtec is offline
post #8 of 9 Old 12-13-2019, 02:02 AM
MaskedMallard
Xj
CJ7-Tim is correct, they would be able to drive off with the Jeep, if the key was found. So, you could always cut the head off the key & glue the Gray plastic key head as close to the ignition lock cylinder as possible. Just open up the plastic steering surround & glue it in place.
I'd guess the cost of a PCM (Power Control Module / Computer) can be had for less than $100.00, even cheaper if you can go to a U-pull salvage yard. If you are worried about the SKIM system failing.
What color was your key head, that was then copied at HD? Gray or Black?
The plastic gray key head has SKIM.
The plastic black key head does not have SKIM.
post #9 of 9 Old 12-14-2019, 09:33 AM
Camaro45th
Black. But good to know. I know I have seen those Gray keys in the wild on a few vehicles.
