2000 Cherokee Sport (XJ) - JeepForum.com
 2Likes
  • 1 Post By CJ7-Tim
  • 1 Post By CJ7-Tim
post #1 of 11 Old 09-29-2021, 02:44 PM Thread Starter
cmbl1122
Hello, my XJ was stolen, the immobilizer was damaged and I can't get it to run now. It will start with the remote start for 2 seconds and the quit. Does anyone know how to bypass the immobilizer to get the vehicle to run?
Thanks
Joel
cmbl1122 is offline
post #2 of 11 Old 09-29-2021, 03:13 PM
jtec
jtec's Avatar
2014 JK Wrangler
Is ths a European model?
Why - a different system may have been used there.
But as your system is turning off fuel @2seconds I would suspect there are codes.
The codes would tell WHAT is the issue. Keys, wiring, SKIM.
As the vehicle was stolen might want to look at SKIM in steering column - damaged, wires damaged.
I would suspect wires AFU.
jtec is online now
post #3 of 11 Old 09-30-2021, 09:07 AM Thread Starter
cmbl1122
Hello, it is an American model. The immobilizer was damaged, I attempted to repair it, not sure if it worked. I will have to get a code reader and try and trouble shoot. Any additional advice is well appreciated!!!
Joel
cmbl1122 is offline
post #4 of 11 Old 09-30-2021, 10:12 AM
jtec
jtec's Avatar
2014 JK Wrangler
keep the SKIM you have.
Knowing WHAT the PCM is missing is where I would start, check codes, likely P1685 & p1686.
AT least we will know where to concentrate.
jtec is online now
post #5 of 11 Old 10-02-2021, 11:06 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The engine starting and then shutting OFF after 2-3 seconds means the SKIM/SKIS anti-theft system is activated. The only options are to tow it to a Dealership that can use the DRB-III Scan Tool to re-flash the PCM, replace the PCM and SKIM/SKIS chip-in-key reader module, or to remove the PCM and SKIM/SKIS chip-in-key reader module.
The low cost solution is to buy a compatible XJ PCM and delete the SKIM/SKIS chip-in-key reader module. If you install a different PCM that is not mated to the SKIM/SKIS module by the Dealership, it will lock up after several tries to start the engine.
The mid cost solution is to buy a properly mated XJ PCM and SKIM/SKIS chip-in-key reader device from a compatible junkyard XJ or part out.
I prefer an aftermarket alarm with ignition disable to the factory SKIM/SKIS. New chipped keys programmed for the SKIM/SKIS are expensive.
Wyo likes this.
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #6 of 11 Old 10-03-2021, 11:09 AM Thread Starter
cmbl1122
Thanks. I will start there and keep you updated with my results!
cmbl1122 is offline
post #7 of 11 Old 10-03-2021, 11:41 AM
CJ7-Tim
CJ7-Tim's Avatar
Try to find a compatible PCM locally from a junkyard or somebody parting out, refurbished PCM's from on-line sellers are often defective or simply dead on arrival.
A 2000 4.0L XJ could have either 49 state emissions and only 2 O2 sensors, or it could be California Emissions with 2 cat converters under the exhaust manifold and 4 O2 sensors. Your replacement PCM will need to have the same part number as the PCM you have now, and not come from an Xj Cherokee with SKIM/SKIS installed.
Fourspeedman likes this.
CJ7-Tim is offline
post #8 of 11 Old 10-13-2021, 12:13 PM Thread Starter
cmbl1122
Hello again. A quick question, with the catalytic converter stolen and the vehicle not running for more than 2 seconds, is there a way to bypass the problems I am having a get the Jeep started so I can move it? It is currently sitting in my garage here in Minneapolis, MN.
Thanks
Joel
cmbl1122 is offline
post #9 of 11 Old 10-13-2021, 03:33 PM
CJ7-Tim
CJ7-Tim's Avatar
The engine will run without a cat converter, but it will not run longer than 3 seconds if the SKIM/SKIS anti theft system is engaged. You will need to have the the SKIM/SKIS anti theft PCM re-flashed, or delete the anti theft system and install another PCM.
Send me a Private Message, I may have a spare 2000 PCM.
CJ7-Tim is offline
post #10 of 11 Old 10-13-2021, 07:01 PM Thread Starter
cmbl1122
2000 xj
Hello, I am new to this and I don't have a FB account. Is this how to send a private message?
Thanks
Joel
cmbl1122 is offline
post #11 of 11 Old 10-14-2021, 04:44 AM
CJ7-Tim
CJ7-Tim's Avatar
Left click on my user-name or try this >> https://www.jeepforum.com/forum/priv...o=newpm&u=4514
CJ7-Tim is offline
