1999 Jeep cherokee transmission issue - JeepForum.com
post #1 of 7 Old 06-19-2019, 01:32 PM Thread Starter
Mud4Life
I have a 99 xj sport 4.0L aw4. When I got the Jeep it “needed a trans” it was stuck in 4th gear when it was in drive. When shifting manually the Jeep didn’t slip or anything. Drove fine. First I changed the throttle body with another I had and it started shifting better. Then it started slipping again. I ended up taking solenoids out of another aw4 I had and changing the fluid. It shifted fine and didn’t slip for about 15 minutes. Then it started slipping again. I took another aw4 I had and swapped the whole trans out and added new fluid. Now it is shifting between gears in drive, but is slipping into gear and slipping while driving. It has the correct amount of fluid in it. Anything else I should try before trying a different trans? I’m not sure what condition this new trans is in, but I’ve never really had a bad aw4. I also adjusted the kickdown cable. Thanks!
97 wrangler sport 3.25" sl, 1.25" bl, 35.
93 cherokee sport
Mud4Life is offline
post #2 of 7 Old 06-19-2019, 04:06 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Are you using Dexron-III/Mercon transmission fluid, and filling/checking for the correct level of fluid ?
Is the Check Engine Light ON ?
What year XJ was the donor of the swapped transmission ? Not all AW-4's interchange.
I would go on the Google and find the Jeep AW-4 Service Manual. In the manual is filled with diagnostic and testing information. Shot gunning random parts at an undiagnosed problem is seldom very effective.
CJ7-Tim is offline
post #3 of 7 Old 06-19-2019, 04:16 PM
jtec
2014 JK Wrangler
this is a 1999 so I would suggest a SCANNER to see if any codes.
jtec is offline
post #4 of 7 Old 06-24-2019, 06:23 AM Thread Starter
Mud4Life
I’m using atf +4 and it is at the correct level. Checked in neutral, warm, and on level ground. The check engine light is not on. My scanner only reads codes that are stored with a light on. I will look into a more advanced scanner. The Trans came out of 99. I believe they all interchange 98-01. I will try a google search as well for the manual. Anything else that might be causing this?
93 cherokee sport
Mud4Life is offline
post #5 of 7 Old 06-24-2019, 06:24 AM Thread Starter
Mud4Life
Will get a better scanner this morning and check it.
93 cherokee sport
Mud4Life is offline
post #6 of 7 Old 06-24-2019, 08:18 AM
CJ7-Tim
CJ7-Tim's Avatar
Originally Posted by Mud4Life View Post
Im using atf +4 .
Using ATF+4 in the AW-4 has been known to cause slippage. You should be using the specified Dexron-III/Mercon.
CJ7-Tim is offline
post #7 of 7 Old 06-24-2019, 08:41 AM
jtec
2014 JK Wrangler
many of us here have the manuals, concentrate on the scan and getting correct fluid and a filter.
Do not change the fluid and filter BEFORE we check codes - don't want to drop pan again to address a internal issue.
Ask if you will want a manual and can do the trans checks - the team will help
jtec is offline
