1998 Cherokee XJ Aftermarket Stereo Ground - JeepForum.com
post #1 of 5 Old 06-27-2019, 04:24 PM Thread Starter
milohodges
Hello, first post here,
I have a 1998 Jeep Cherokee XJ and just got a new pioneer head unit in the mail from curt field with their “ReadyHarness” service where all the wires are pre connected. But, the ground wire is connected to a small loop and I cannot connect this to the existing stereo ground that connects to the original stock cassette/tuner stereo. Do I have to connect it to the stock wire or can I connect the loop ground to something else? Thank you for any and all help.
Below is a photo of the “loop ground” wire I am referring to
milohodges is offline
post #2 of 5 Old 06-27-2019, 11:15 PM
S8NNG8
S8NNG8's Avatar
1995 XJ Cherokee
Find a screw in the firewall or the steel structure of the dash and put it on like a washer. If that loop is too big for the head of the screw use a washer on top of it.
D3<!L!>3D
S8NNG8 is online now
post #3 of 5 Old 06-28-2019, 05:59 AM
75SV1
The chassis is the ground. I think when I did mine, I extended the wire and used one of the screws near the trans tunnel on the driver's foot well side. I also put in an amplifier just above the radio. It was a smaller $100 one. I had planned to put components speakers in the door, so I needed an amp.
75SV1 is online now
post #4 of 5 Old 06-29-2019, 10:23 AM
Saudade
1988 XJ Cherokee
Well, that ring terminal is absurdly large. Likely intended it to go under a bolt or nut under the dash. In the end, a ground is a ground. Replace the terminal with a smaller one and use any screw into the metal structure, or splice it into an existing ground wire.
Saudade is online now
post #5 of 5 Old 06-30-2019, 02:38 PM
JWELK
The OEM factory radio had a female spade lug in the black jack. Replace this ring lug with a standard sized male spade lug.
JWELK is offline
