1996 Cherokee 4.0 HO low voltage to coil and no voltage to injectors - JeepForum.com
post #1 of 4 Old 04-11-2018, 02:12 PM Thread Starter
rth781
A friend of mine has a 1996 Jeep cherokee with a 4.0 HO manual getting only around 4 volts to coil and and nothing to the injectors. He has replaced coil distributor cps and all fuses have been checked. Cleaned all grounds any advice would be appreciated. Thank you
rth781 is offline
post #2 of 4 Old 04-11-2018, 02:29 PM
2oldjeeps
wires,fuses, switches, relays.
look at wiring diagram.
2oldjeeps is offline
post #3 of 4 Old 04-11-2018, 02:33 PM
jtec
2014 JK Wrangler
both circuits (coil injectors) are powered by ASD relay.
Was the coil unplugged? and which wire had 4v?
Ant recent work, repairs mods?
Can you/friend use a test lamp or DVOM and a wiring diagram ?
jtec is offline
post #4 of 4 Old 04-11-2018, 03:32 PM Thread Starter
rth781
The green red has the 4 volts brown or purple is showing 2 volts. Yes the coil was unplugged
rth781 is offline
