1995 xj cherokee rear diff noise. - JeepForum.com
post #1 of 6 Old 08-14-2014, 05:36 PM Thread Starter
daximus27
Hi everyone this is my first post and new here. i own a 1995 xj jeep cherokee here i Australia i bought the car around 2 weeks ago and have notice that there is a common whining noise in the rear diff is louder at 50km/h which is around 30mp/h. but the faster the car goes the whine reduces at 90km/h and over the noise is gone. have change diff fluids and have checked all gears when i removed the dana 35 cover and found no signs of damage or metal shavings. also theres no wheel play and all the u joints seem good with no play. i ve heard that this are common to be noisy and as long as i maintain the oils they go for ever. Forgot to mention my is a lsd as well as the tag says use lsd lube which i have. other than that car drives fine. the reason i notice the car making noise is that around my town all speeds are set to 50km/h 30mp/h and thats when i notice the sound but when i go on the high way 70km/h to 100km/h 43mp/h to 62mp/h the diff noise is reduce and is barley noticeable. no shakes or nothing.
Any input would be great and Thank You heaps for your time taking in reading this much appreciated.
daximus27 is offline
post #2 of 6 Old 08-15-2014, 11:08 AM
1stockjeep
1993 XJ Cherokee
How's the pinion bearing play? Grab the yoke on front of diff and see if it has any up and down movement. A little is expected but a lot means the pinion bearing is bad
1stockjeep is offline
post #3 of 6 Old 08-15-2014, 01:14 PM
Amesbear
I agree with 1stockjeep. If everything inside the diff looks fine then you probably have a bearing going bad.
My XJ thread: https://www.jeepforum.com/forum/f177/im-back-xj-2628914
Amesbear is offline
post #4 of 6 Old 08-15-2014, 01:27 PM
M35A2
1995 XJ Cherokee
Did you use a synthetic oil? Mine made the same noise you describe when I got it. all fluids were changed when I made my purchase by the PO, had receipts for all the maint with the truck, they used synthetic oiol. I hated the noise, so I switched to regular petro based oil, the noise is gone.
Volunteer, American Society of Military History. http://tankland.com/
Just got a 1989 YJ too!
M35A2 is offline
post #5 of 6 Old 08-15-2014, 08:20 PM Thread Starter
daximus27
Hi i used normal diff oil not synthetic, and no play in yoke it has a small play when you turn it either side like it so pose to but not up and down cheers
post #6 of 6 Old 08-15-2014, 09:33 PM
calvin196
If the noise you're experiencing isn't constant but mainly increases due to acceleration I can almost assure you it's your rear 'wheel bearings'. I had lots of noise coming from the front and rear of my 01 XJ and was very used to it. I then replaced my front hub assemblies (wheel hubs) and my rear bearings and seals and after driving I was amazed how much quieter the jeep drove. I didn't notice any increase in 'drive ability', the only thing I noticed was less noise. If you're on a budget and if the noise isn't constant and or worrying you too much then don't change it. Follow this very useful motto 'if it aint' broke don't fix it'.
Enjoy.
calvin196 is offline
dana 35 , differential , whining noise
