1992 cherokee larado no start - JeepForum.com
post #1 of 15 Old 09-03-2008, 09:57 PM Thread Starter
blue96jeep
hey all,
i just picked up a 1992 larado with 170mi on the clock, the guy i got it said it ran rough and had a metal to metal sound. well once i got it home started to diag it, here is where i got so far metal sound is cat hitting cross member due to vibratiing so much from running rough, no biggie. running rough well..... turns out spark plugs gaped wrong and cap and rotor show signs of wear. so i replaced the plugs, cap, and rotor but kept wires they looked ok. now i have a no start but cranks.
so my questions are i have a 1996 FSM for my 96 cherokee, and is the information the same, if not where could i get 1992 info from.
cause right now i have the plugs on the cap in the order the FMS says, so i am thinking i have the wires on the cap wrong, because it ran badly before i changed everything, but it ran. and i check the gap on the new plugs set at .35
thanks
Ryan
blue96jeep is offline
post #2 of 15 Old 09-03-2008, 10:02 PM
dualsub2006
PM me your email address.
dualsub2006 is offline
post #3 of 15 Old 09-03-2008, 10:13 PM
dualsub2006
I missed the part that you were just looking for the firing order. According to the information that I have from the 84-93 FSM:
Firing order for 91-93:
V6 - 1-2-3-4-5-6
I6 - 1-5-3-6-2-4
Spark plug gap is .035 for all years 84-93.
post #4 of 15 Old 09-03-2008, 10:15 PM
kg4kzv
1995 XJ Cherokee
see if this see if this maybe this will help post helps confused your not the only one.
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline
post #5 of 15 Old 09-03-2008, 10:24 PM Thread Starter
blue96jeep
thanks for the quick replys, the posts about the firing order is the way i have it set up right now so i dont thing the problem is there, unless it not getting a spark.
so can i use the information from my 96 FMS on the 92 i just bought
ryan
post #6 of 15 Old 09-03-2008, 10:42 PM
kg4kzv
1995 XJ Cherokee
A lot of stuff will be the same between the 92 and the 96 but there are some important changes in the engine control areas. as well as engine cooling systems. Others may chime in on other differences.
For the no start go back over everything because it is common to knock lose a plug or something while doing a tune up.
Chris.
kg4kzv is offline
post #7 of 15 Old 09-03-2008, 10:53 PM Thread Starter
blue96jeep
ok well i will be doing more diag tomrrow
ryan
post #8 of 15 Old 09-04-2008, 08:01 PM Thread Starter
blue96jeep
here is a update on the diag i did today, i had battery tested and charged so that good, i can hear fuel pump priming, starter is working, i even swapped the wires from my DD to this one with no avil.
so now i am thinking it might be the ignition coil not working, but not sure have to check for spark at the coil and at the plugs.
if i am missnig something please chime in
ryan
post #9 of 15 Old 09-04-2008, 09:28 PM Thread Starter
blue96jeep
bump......
post #10 of 15 Old 09-04-2008, 09:33 PM
kg4kzv
1995 XJ Cherokee
You need to check for spark so that we can go from there. Still looks like something got bumped or moved since it was running before tune up and won't start after.
Chris
kg4kzv is offline
post #11 of 15 Old 09-05-2008, 06:51 PM Thread Starter
blue96jeep
ok people i need help this no start has got me......
battery-good
fuel-hear pump prime & fuel at the rail
coil and cap- both have spark, nice and purple
air filter-ok
thanks
ryan
its a 92 jeep cherokee larado
post #12 of 15 Old 09-05-2008, 09:08 PM
dualsub2006
battery-good
air filter-ok
thanks
ryan
What is the fuel pressure at the rail?
post #13 of 15 Old 09-05-2008, 10:25 PM Thread Starter
blue96jeep
i dont know what the pressure is didnt test it...yet will so need to get a tester
ryan
post #14 of 15 Old 09-05-2008, 10:41 PM
dualsub2006
Auto Zone had one to loan when I tested mine. They let me take it home because they knew me. If your local one knows you well enough to laugh when they see you coming they may let you borrow it.
post #15 of 15 Old 09-05-2008, 10:53 PM Thread Starter
blue96jeep
good thought... will ask tomrrow
ryan
1992 Jeep Cherokee new rebuilt Engine will not Start XJJeepfreak XJ Cherokee Technical Forum 27 02-25-2010 06:27 PM
89 Cherokee larado hard to start Jeepedo XJ Cherokee Technical Forum 2 09-08-2009 10:22 AM
95 jeep cherokee larado wont start makes clicking noise ewaltjcl XJ Cherokee Technical Forum 8 01-29-2009 07:20 AM
1992 4.0L cherokee turns over but will not start?? spanish_lad XJ Cherokee Technical Forum 27 08-04-2008 11:14 AM
4X4 Shifter Linkage 87 Cherokee Larado FrankEllijay XJ Cherokee Technical Forum 1 10-06-2005 01:13 AM
