1990 XJ Electrical Gremlins-No dash lights, no tail lights - JeepForum.com
post #1 of 12 Old 03-08-2019, 08:32 AM Thread Starter
lrsmithwhaley
1990 XJ Cherokee
Exclamation 1990 XJ Electrical Gremlins-No dash lights, no tail lights
Not sure if it's related, but I have no tail lights and no dash lights. I keep blowing Fuse 7 which according to the following diagram is Parking Lights, Headlight Warning Chime/Buzzer, Instrument Panel Light Dimmer. I've checked the rear lights and can't find any issues. I unplugged the trailer wiring harness thinking that was the issue and still blew a fuse. I unplugged the clock (dash lights started having issues when the push buttons got stuck) and that didn't fix it. Not sure where, or what to start messing with now.
http://jeep-manual.ru/index.php?page=105
Green with Silver trim 1991 Jeep Cherokee Laredo (DD and Off-roader)
March 2007 Stock Class XJ of the Month
Original Rust Jeep Club Member #2
Green Jeep Club Member #183
Air Force Jeep Club #76
lrsmithwhaley is offline
post #2 of 12 Old 03-09-2019, 06:13 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Install a new radio lately?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 12 Old 03-09-2019, 06:58 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Be specific, what exactly did you do when checking the rear lights ?
As already suggested, what are the most recent medications/additions/repairs to the circuits involved ?
If you are blowing fuses, there is fault, failure, or short circuit to be located and repaired.
You should be physically/visually inspecting and multi-meter testing continuity in all the related/fused:
  • light sockets
  • grounds
  • wire harnesses
  • switches and dimmers
“We the people are the rightful masters of both Congress and the Courts,
not to overthrow the Constitution but to overthrow the men who would pervert the Constitution” Abraham Lincoln, 1859.
CJ7-Tim is offline
post #4 of 12 Old 03-09-2019, 08:36 AM Thread Starter
lrsmithwhaley
1990 XJ Cherokee
It's an aftermarket radio that the PO installed. It's been in for a good year now without issue. Nothing new recently. I started having electrical issues around the time I went to adjust the built in clock and the little buttons got stuck (clock displayed 8888). I did some trouble shooting and it blows a fuse as soon as I pull the switch to turn on the lights. Until that point the door buzzer works and dash lights work. The headlights stay on, but the rest of the fused items (buzzer, dash lights, tail lights) stop working. I removed the clock and still blew fuses. I had someone else check the wiring with a multi-meter at the plugs and they said it was good. It's possible they didn't know what they were doing though. The ground is good and I've removed the trailer harness to make sure that wasn't causing an issue. The only things I haven't taken apart and checked are the pull out light switch and the buzzer as I'm getting mixed answers on where the buzzer is for this year.
post #5 of 12 Old 03-10-2019, 08:17 AM
Gremmy
1989 XJ Cherokee
I had this similar issue no tail lights, head lights, dash lights, so replaced the headlight pull out it as it was smoking so easy decision.
Gremmy is offline
post #6 of 12 Old 03-10-2019, 08:35 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Take the taillight bulbs out and inspect them and the sockets.
post #7 of 12 Old 06-10-2019, 09:56 PM
husker88jeep
1988 XJ Cherokee
I had the same issue going on and it came back to two blue wires and a black wire in the rear hatch were connected together when I put in aftermarket speakers ..the double blue wires have a female plug and they sit right next to a black wire with a male plug and I must've thought those go together so I plugged them in... well that's when I started blowing fuses...I did a google search and someone suggested to check those and EDIT....it did not fix my issue...looking for the same fix as OP...Help?????
husker88jeep is offline
post #8 of 12 Old 06-14-2019, 09:28 PM
husker88jeep
1988 XJ Cherokee
bump
post #9 of 12 Old 06-14-2019, 10:03 PM
CodemanLivs
CodemanLivs's Avatar
1995 XJ Cherokee
Use a volt meter set for continuity. Put one lead on the blue wire and one on the black wire if reads a connection then those wires melted together somewhere down the line. Find it separate them repair the damage and try again. Same goes for the OP. You have a short somewhere. Unplug your headlight switch. One test lead to a good known ground and with the other lead start probing each terminal on plug you took off the switch. Only the ground wire should read continuity. If any other wire does then follow that wire to the melted spot.
CodemanLivs is offline
post #10 of 12 Old 06-15-2019, 06:56 AM
CJ7-Tim
CJ7-Tim's Avatar
Originally Posted by husker88jeep View Post
bump
You should be physically/visually inspecting and volts ohms multi-meter testing continuity in all the related/fused circuits:
  • light sockets
  • grounds
  • wire harnesses
CJ7-Tim is offline
post #11 of 12 Old 06-17-2019, 03:24 PM
Sam-daily
Sam-daily's Avatar
Heres a link to the FSM. Also, alot of things run through the rear window defroster that have no buisness doing so.
http://www.pacificcoastmanuals.com/j...e_manuals.html
Sam-daily is offline
post #12 of 12 Old 06-24-2019, 04:32 AM
Swampdweller-nz
I had a similar issue recently and had no tail-lights and no dash lights. Only discovered the fault when plugging in a trailer connection, and testing the trailer lights. Replaced fuse and it blew immediately the tail-light circuit was turned on.
Continued to blow fuses with the trailer disconnected so I went through all my wiring at the rear of the vehicle. Did all the standard checks - bulbs, fittings, wiring - and nothing seemed to have any obvious faults.
Finally got to the front of the vehicle and noticed that the left front park-light bulb had blown. Replaced the bulb, and it still shorted. On closer inspection of the bulb-holder I noticed that there was a small piece of bare wire where the cable had chafed though on the headlight bucket. Repaired the wiring, and end of problem.
Do the simple checks first! And just remember that your front park-lights are also part of your tail-light circuit, so don't forget to look there as well - it might be as easy as my fix.
Every day is a good day, but some are better than others
Swampdweller-nz is offline
No Dash or tail lights. djnspencer XJ Cherokee Technical Forum 12 12-12-2018 02:07 PM
2000 Grand Cherokee Limited - No Head, Tail, or Dash Lights No_Traction WJ Grand Cherokee Forum 2 08-16-2018 09:37 PM
01 Wrangler electrical issue (running lights & dash lights) FixJade TJ Wrangler Technical Forum 25 06-23-2018 07:25 PM
Electrical gremlins in dash!! Help!! Kinardg7 Audio, CB & Ham Radios, GPS, & Electrical 0 03-26-2018 10:51 AM
97 XJ no dash lights, tail lights or parking lights MaddogCherokee XJ Cherokee Technical Forum 3 12-23-2017 08:18 AM
