1990 XJ 4.0 L wiring help - JeepForum.com
post #1 of 4 Old 08-10-2016, 09:14 PM Thread Starter
jeepinandy58
Got an 4.0 from a 90 XJ and I could really use some help with the wiring. I have the wiring diagram but don't know what the connectors go to. The pictures show a connector that comes of the stator assy and alternator; from the diagrams, these go to the ECUbut the connector shown does not connect to anything on the harness that I have. I have a feeling there is a male/female connector that is missing but need to confirm it. Can I get someone with a 90 XJ, 4.0 l take a picture for me so I know whether to look for a connector or just go ahead and start hard wiring it?
jeepinandy58 is offline
post #2 of 4 Old 08-12-2016, 06:51 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The wire from the stator runs toward the front, is clipped on the motor mount bracket and is part of the harness that has the oil pressure sender wire in it.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 4 Old 08-15-2016, 07:37 PM Thread Starter
jeepinandy58
1990-xj-4-0-l-wiring-help
Thanks Cruiser,
That's correct and they are connected to the stator, oil pressure sending unit and alternator. What I am trying to find out is how the grey connector in the picture connects to the harness and eventually to the ECU. It appears (at least to me) that the grey connector plugs into a male connector with the other side being a female connector. I went to a couple of junkyards this weekend and couldn't find what I need to see. Does your MJ have the grey connector like the picture, and if so, is there any chance I could get you to take a picture of it? (Where it is mounted, etc.) If I have to, I can cut connectors and hard wire it all, but I really don't want to go that route unless it is absolutely necessary.
post #4 of 4 Old 08-15-2016, 07:39 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I think the gray and black connectors are for the TCU etc.
Click below:
http://cruiser54.com/?p=58
