1990 AW4, Roar and 3 not passing - JeepForum.com
post #1 of 6 Old 06-04-2016, 02:33 PM Thread Starter
Godzilla_janus
Xj 1990 AW4, Roar and 3 not passing
Hello,
My old '90 XJ has an issue with its AW4 trans :
Everything begun with a roaring sound while driving. Nothing that scared me. I am used to new noises, and in generally it ends with removing some mud from wheels, brakes ... So I kept on driving ...
But, things went worse : 3rd speed refused to come ! When removing the TCM fuse, all 3 speeds pass easyly, but always with that roar on 3. No roar on 1/2.
Before that issue, the engine coolant boiled a little due to a too old water bottle cap, but the needle never went to the red line.
ATF 4 is clear, red, no smell, and the quantity looks ok. linkage seems OK.
When I go from "3" to "N" at the same speed (down hill), the roar stops. I a m pretty sure roar comes from tranny.
Any idea ?
Thank you for your help
WJ 4.7 no HO
XJ 4L RENIX
ZJ 5.2
XJ 2.1 Diesel
Godzilla_janus is offline
post #2 of 6 Old 06-05-2016, 02:19 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
First off, that's the wrong fluid for an AW4. Dex/Merc only.
Your TCU could have a bad ground and your wiring between the trans/TCU/sensors could be an issue.
I would recommend doing the following Tips to eliminate them as a possible cause:
http://cruiser54.com/?p=19
http://cruiser54.com/?p=58
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 6 Old 06-05-2016, 02:40 PM Thread Starter
Godzilla_janus
Thank you very much !
I will try that and keep you informed.
Regarding, the fluid, there is a Jeep SB saying to use ATF4 in AW4. But maybe not with these old Cherokee's ?
post #4 of 6 Old 06-05-2016, 02:49 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
SB is wrong.
post #5 of 6 Old 06-06-2016, 11:38 AM Thread Starter
Godzilla_janus
Xj
Thank you Cruiser !
A little spray on these connectors, plus the TPS, and hop, the 3 goes on !
Now, I must find what is the cause of the roar ...
WJ 4.7 no HO
XJ 4L RENIX
ZJ 5.2
XJ 2.1 Diesel
post #6 of 6 Old 06-06-2016, 02:07 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
See tip 1 about the dipstick tube ground also.
