JeepForum.com (https://www.jeepforum.com/forum/)
-   XJ Cherokee Technical Forum (https://www.jeepforum.com/forum/f11/)
-   -   1987 4.0 Renix wiring help (https://www.jeepforum.com/forum/f11/1987-4-0-renix-wiring-help-4143465/)
MOBBiN 08-20-2017 06:41 PM
I'm working on undoing all the PO's work. I have a few thinking in need to wrap up. Any help would be appreciated
Starting on the drivers side...
1.throttle body. Is the top hole is open. Should it be plugged in to anything or filled
http://i176.photobucket.com/albums/w...pstqgo82ma.jpg
2.back of the block near injectors 5 & 6
http://i176.photobucket.com/albums/w...pska8eupw1.jpg
3. Back of the block near injector 6
http://i176.photobucket.com/albums/w...psk05lhwlc.jpg
4. Plug by the air box. Pretty sure this is for the e-fan... because its missing
http://i176.photobucket.com/albums/w...pswzpjwoei.jpg
Passengers side
5. Plug with TCM grounds
http://i176.photobucket.com/albums/w...psp9un7nls.jpg
6.
http://i176.photobucket.com/albums/w...ps9uu4d9p9.jpg
7. Purple plug coming out of the back of the heater box grommet
http://i176.photobucket.com/albums/w...psytq0rm02.jpg
8. Red wire coming out of the harness by the battery
http://i176.photobucket.com/albums/w...psnc3ncp7c.jpg
cruiser54 08-21-2017 06:27 PM
1: http://cruiser54.com/?p=280
2:Dash water temp gauge connector. You have the wrong sender in your head.
3:See 2^^.
4:Yes
5:I can't see what you're taling about.
6:4WD light switch connector?
7:Goes to the heater control valve which you might not have. Plug it.
8:Not stock looking.
The time now is 01:17 AM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
