What kind of tow rig do you have? - Page 31 - JeepForum.com
 5Likes
post #451 of 473 Old 05-13-2014, 07:42 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
1994 ZJ
Buddies Cummins towing his Toyota cab buggy
Brothers HD towing my K5
and my 'Stroke towing a toyota cab buggy and a ZJ in the Enclosed trailer
1994 ZJ-- bone stock for now
2005 GMC 2500HD 496 C.I. tows it all
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #452 of 473 Old 06-02-2014, 01:50 PM
nate_053
While on your search for a new truck, you can type in the year, make and model at reesehitches.com to find out your options for towing capacity. Might help make your decision easier!
nate_053 is offline
post #453 of 473 Old 08-29-2014, 07:36 PM
Boog
Picked this up today. 2002 Chevy 2500HD with the 6.6L Duramax under the hood.
2008 JKU Sport- Purchased Feb '17
2001 TJ Sport- Sold Sept '15
Air Force Jeep Club #147
Boog is offline
post #454 of 473 Old 08-31-2014, 05:01 PM
aircruiser
aircruiser's Avatar
Picked this up couple months ago, it was bone stock when I got it I added the Hummer H2 wheels and 285 tires, 08+ badges and tow mirrors.
I bought it from the original owner with 112k miles on it, garaged its whole life, not a dent or spec of rust on the body! Its an 03 LB7 duramax, allison, 4x4, CCSB
And heres my tow rig for work
aircruiser is offline
post #455 of 473 Old 09-07-2014, 07:33 PM
youngjeepr
youngjeepr's Avatar
Here is my tow rig pulling my buddies XJ
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #456 of 473 Old 09-15-2014, 06:15 AM
GoodtimeKenny
GoodtimeKenny's Avatar
My rig
2005 F-150 King Ranch Crew Cab, 6 inch Rough Counrty Extreme lift, 35x12.50R18, Edge programmer, K&NName:  truck.JPG
GoodtimeKenny is offline
post #457 of 473 Old 10-06-2014, 04:12 PM
Alroundj
2005 WK
'05 Jeep Grand Cherokee 4.7l. Eibach springs, addco sway bars, Gibson Exhaust and k&n cold air.
Alroundj is offline
post #458 of 473 Old 07-10-2015, 02:17 PM
lutzke21
lutzke21's Avatar
Got a new tow pig... just need a trailer now.
-Scott
'94 YJ on 35s
M C L M M
lutzke21 is offline
post #459 of 473 Old 08-22-2015, 06:32 AM
WV_Jeeper91
1994 GMC Sierra C1500 with a 4.3L V6. It's almost completely stock except for the typical TBI modifications and dual exhaust. The trailer in the picture didn't have brakes either.
WV_Jeeper91 is offline
post #460 of 473 Old 08-22-2015, 04:47 PM
youngjeepr
youngjeepr's Avatar
how does it pull?
post #461 of 473 Old 08-22-2015, 08:23 PM
WV_Jeeper91
It did better than I anticipated. It's been a few years so the details are a little fuzzy but on flat ground and on slight grades it could've went as fast as you wanted. Curves were sketchy though, I took everyone of them slow too. Going up a steep hill it did run a bit hot and was having a hard time but it did make it up there. I honestly had no problems slowing it down either. The Jeep weighs more than most probably and it was a 16 foot utility trailer. The truck like I said is mostly stock. It has a tube instead of a silencer, V8 air cleaner, k&n filter, hypertech base, ported throttle body, pod spacer, throttle body spacer, dual exhaust and the timing advanced 4 degrees. It's auto truck with 3.42 gears and 235/75R15 tires. I've had it for about 8 1/2 years. Without the throttle body ported and timing set at a stock 0 degrees it put down 130 hp and 200 ft lbs (it should've been higher but the run didn't start slow enough). It's far from anything impressive but it'll do the job. The last time I towed the Scrambler I flat towed it using a tow strap. Could hardly tell it was back there but we didn't go over 40 mph. I actually have a J10 that I'm hoping one day might be done for towing duties. That way I can have a Jeep towing a Jeep.
post #462 of 473 Old 11-21-2015, 08:39 PM
BowtiePimp
My tow pig is a 2005 Chevy Silverado custom made shortbed Duramax dually lowered with 24" freightliners....
BowtiePimp is offline
post #463 of 473 Old 11-22-2015, 06:57 PM
222Doc
222Doc's Avatar
96 F250 7.3
222Doc is offline
post #464 of 473 Old 05-15-2017, 09:04 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
'12 Ram 3500 6.7 cummins
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #465 of 473 Old 06-23-2018, 12:01 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Bought a new tow rig a while back. '17 Ram 3500 6.7L CTD 4x4. I've added a few things since this pic pulling my bass boat. I'm shopping for a slide in camper right now.
Fourtrail likes this.
Joe Dillard is offline
What Kind Of Dog Do YOU Have ? Ibreakevrything General Discussion 189 03-27-2013 01:24 PM
what kind of gps to buy rubicon35 General Discussion 10 06-28-2008 12:39 AM
Kind of Disgusted... Kind of Saddened prd_cdn General Discussion 14 04-15-2008 04:18 AM
New kind of Mandymiles1995 General Discussion 6 02-11-2006 09:52 AM
wut kind???? fisher446 General Discussion 1 08-08-2005 01:14 PM
