NumbLost's Trailer Design & Build - JeepForum.com
post #1 of 5 Old 03-09-2019, 09:13 AM Thread Starter
NumbLost
2018 JK Wrangler
Introduction
Like many people before me and probably many more after, I have come to the realization that purchasing an already made trailer to the specifications I am looking for is nearly impossible. I have spent countless hours over the last couple months researching this topic and the more I dive in the more I realize what I am trying to achieve will need to be fabricated, not purchased ready-to-go, and cost twice what I had hoped to pay. I've seen the military trailers, Harbor Freight, and Carry-On builds and decided those are not what I'm looking for but threads like armyRN's inspired me to create this one in hopes of helping anybody else who is looking for something similar.
Background (skippable but relevant section)
In 2005 my friend and I refurbished an old homemade utility trailer (Before & After photos shown) but that trailer needs serious work. The floor needs to replaced, there are issues with the suspension causing it to heavily sag to one side, and it needs a new paint job. I have a 2018 2-door JK and given the listed problems and the height of the sides, I don't like the idea of towing it with a load on the highway. I'm used to driving longer landscaping trailers with 1-ton dump trucks but the one time I did take it on the highway I had a feeling it may act like a sail with a strong gust of wind.
Constraints
  1. I live in an apartment so work will have to be done either at my place of work or my parents garage. There are many pros/cons to both places.
  2. I do not know how to weld.
  3. I am not a carpenter.
  4. I have only basic tools.
  5. Low budget.
  6. 2,000 LBS GVWR.
Purpose & Specifications
I'm looking for something with a form-factor similar to the camping/overlanding/tub trailers out there. This will be used primarily to haul firewood and camping gear with a heavy emphasis on the firewood. It will be mostly used on paved roads, driving over a curb and across lawn, and the hilly dirt/rocky roads of the campground. I was thinking a minimum of 15" tires but I definitely do not need the same tires I run on my not-lifted JK (maybe 32 or 33s?). I already have a 1&7/8's ball hitch and I'm hoping to have a level coupler height of somewhere close to the 16" or so that it sits off the ground.
Here's a rough idea of what I think I want this thing to turn out to be and I'd love to hear feedback! Also see attached sketch of dimensions.
  • 4' tongue to limit jack-knifes and make steering easy.
  • 4'x6' steel tube frame.
  • 10' total length with 2' high sides (part of tube frame).
Wheels, Axle, & Springs
Revised on 3/13/19
LoadStar ST205/75R-15 Radial Tire & Painted Rim: 5 on 5 x2 ~$175
Dexter 64 in. Round Tube Straight Trailer Axle (3500 lb.) ~120
Universal 27" Double Eye Leaf Spring (4 leaves / 1750 lb.) #UNA-210 x2 ~$50
NumbLost is offline
post #2 of 5 Old 03-11-2019, 07:49 AM Thread Starter
NumbLost
2018 JK Wrangler
I found Rezarf's chassis build from 2007 on ih8mud.com and decided to use this as inspiration. I lengthened the tongue by a foot and added the angled tongue braces for stability.
Axle Placement
I've been Googling how to determine axle placement and seen simplified explanations like the 60/40 rule as well as more involved calculations like the one I found at https://mechanicalelements.com/trailer-axle-position/. I gave up trying to use that when I realized I don't have any idea what the trailer frame center of mass might be.
What I do know is that I have a max tow capacity of 2,000#, and a max tongue weight rating of 200#. If I go with my current layout, the total length of the trailer will be 11 feet. The cargo portion will be 6 feet.
If anyone has a better idea of where it should be, I'd like to know.
NumbLost is offline
post #3 of 5 Old 03-12-2019, 08:09 AM Thread Starter
NumbLost
2018 JK Wrangler
Tire Size
I do not need to match the same wheels/tires that I run on my JK because this trailer really won't be doing any serious wheeling and I don't care too much about the appearance matching. I have considered that I may change my mind in the future so I will be going with a 5-on-5 hub for the 3,500# axle. Since I'm trying to have the trailer sit higher than most utility trailers I've come across I'm thinking I may want a tire with an actual diameter somewhere close to 30 inches. I Googled the formula to find the approximate tire diameter based on the 3 number system found on tires so now I will have a better idea of what to look for when it comes time to pick the wheels/tires.
NumbLost is offline
post #4 of 5 Old 05-19-2019, 09:52 AM Thread Starter
NumbLost
2018 JK Wrangler
May 2019 Update
I've decided to go with the following parts. The tires are about ~27" in diameter on 15" wheels. The base frame is going to be 2.5" 11-gauge square steel tubing. It will have a 2' high railing made from 1.25" 11-gauge square steel tubing on three sides. The tongue is going to be 5 feet long. The cargo area will be 4' wide and 6' long. A total length of 11'. I estimate the level tongue height will be about 16.5" to 17" and the total height from ground to top will be about 40". Even though I have a 2k tow limit, I've designed this with 3.5k parts. This might come in handy if other vehicles tow this they can carry more.
NumbLost is offline
post #5 of 5 Old 05-21-2019, 08:16 AM
Fourtrail
1974 CJ6
I would go with the 225-75/15 trailer tires, I know that are way more capacity than you need, but all of the 205's that I have seen look horribly crowned in the center. I would also do trailer brakes from the get go even if you don't put a controller in and use them from the start. They are helpful and will also give you the option for a breakaway box that will apply the brakes if the trailer comes loose. everything else looks good.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is offline
Mini Harbor Freight (type) Trailer Ultimate Build-Up Thread armyRN General Jeep & Off-Road Equipment 3344 05-17-2019 11:55 AM
YJ Build Thread Directory bgredjeep YJ Wrangler Technical Forum 15 12-28-2018 10:09 AM
Falcon Shocks - The New Benchmark in JK Wrangler Shock Design - ONLY THE BEST!! Rockridge4WD Vendor Display 5 08-22-2018 11:43 AM
1947 TJ-2A V1903/32RH/NP231 Kubota Diesel Build on 35s grantsjeep Jeep Builds 0 04-19-2018 11:13 AM
My Solidworks Trailer Build Libtekguy Trailers & Towing 65 02-15-2014 07:06 PM
