I decided to start a thread on my 87' YJ build as I have done quite a few things to it since I got it In April of 2008 til now and I have quite a bit planed for it.
I hope you all find this interesting and I look forward to both positive and negative feedback as I go down this long expensive road in restoring the beast that it is.
I paid $3,000.00 for this jeep with it having no rust, a straight body and 133k miles on it. The 33" tires on it were worn and it had only a 3" shackle lift, 2" body lift for the suspension and upgraded ProComp wheels.
Here's a picture that I took just after I took delivery of it. This was taken after I removed the full soft top as the entire thing was fogged and cracked. I did replace it with a strapless bikini top and replaced the tires with ProComp Mud terrain tires for this pic.
Try and see if yuou can notice the FORD mini van seats that it had…
Shortly after having it for about a month and a half and not really doing much to it I had the large 3" shackles snap the frame hanger bracket. So, I have to remove it and replace it with a new mopar stock hanger. Ahhh, the joys of a shackle lift.
After the whole shacke ordeal, I decided to take some measures and at least make the interior somewhat comfortable and decent. So, I removed the Ford Minivan seas and installed new Bestop recliner seats that I got from jcwhitney. At the same time I ordered a center consol. It's just a cheap "ultimate center consol" that will suffice for now. While the seats were all out I decided to Hurculine the entire inside of the Jeep. I also had to replace the driver and passenger seatbelts as the previous owner mutilated them some how. Not sure but, they were killed!
Did you notice the lame broken steering wheel… Yeah, so it was upgraded to a nice new steering wheel..
With the whole shackle thing that happened I was scared that I was going to snap the other side or worse kill my jeep. A lessonto all and one learned that shackle lifts are dangerous and not worth installing at all… so, I was forced to install a new suspension lift faster than I anticipated.
I decided to go with a ProComp 4" suspension lift with the standard ES 9000 shocks. of course, I had to replace the shackles, I went with stock M.O.R.E. greasable shackles.
Installing this kit was an experience for me as this was the first time that I've done this. I am extremely mechanically inclined and had no real problems. Thanks to all you on here it made things a lot easier after reading up on everything that's been posted on suspension installs here in the forums.
I bought oversized and tall jack stands, a large oversized floor jack, a good torque wrench and stock in PB; lol. I used PB on pretty much every part of the undercarriage a good 2 days before hand to make the removal easier.
The install went smooth other than the SNAFU of ProComp not labeling the springs correctly which made me swap the leafs. I did install the tracbars but not the swaybar. The trackbars may be coming off sooner than later...
Now that I have the lift installed, I decided to work on a few cosmetic things. The large gaudy tubular bomber and rocker guards have to go. Mainly because the rocker guards stick out like a sore thumb because of the body lift and just look out of place. The front bumper is just huge and ugly! Besides we all know that this tubular stuff is not worth the aluminum that it's bent with. So off they came…
Then of course off the front bumper.
Next I think that I'm going to remove and replace the stock steering stabilizer with a new one. Probably wither rancho or ProComp, not too sure yet.
I've finally decided on the paint job that I want. So, I'm now researching body and paint shops around the local area and comparing prices and quality. I've decided to go with the 2007 Corvette orange with extra metallic. Here's the color that I want to paint thanks to a fellow member cjinpa for helping out in the decision, I like the way this CJ looks… Not too sure how my grey interior will look with the orange. But, I think it'll loo good and give it it's own personality.
After the paint job I plan on replacing the rocker guards with something nice and tight to the body… Any suggestions..? Then of course getting some front and rear bumpers. I desperately need to get the spare off the tailgate!
That's it for now, and I', sure there's more to come later
