Yesterday my buddy Aron and I swapped out my 249 with the toasted VC for a 242. This is a 242 from a '96 ZJ. I got this 242 from a guy in CT, Mike (grandman97) lives in the same town and was able to pick it up for me. We then met up at the JF Paragon Run II in October (yep the arctic chill + monsoon run :laugh: ) A big interstate HIGHFIVE to Mike!
Some other helpful links:
http://www.mallcrawlin.com/forum/showthread.php?t=2781
http://jeephorizons.com/tech/tcase.html
The reasons for doing this are in there too. My VC had 175K and was well toasted! I now have low-lock as well.
Here is the case when I got it:
I cleaned it up and tore it down:
(Remove the tail cone (three 15mm bolts) to get to the snap ring, that ring has to come off before you can split the case and pull it apart. Don't loose it!)
Looking at the inside from the rear. The left gear is for the front output, the center rod coming toward the camera is part of the shift mechanism and the right gears and main shaft are all part of the 2WD / PT / FT and low range. Note the snap ring pliers in the bottom right, get a better pair, the wider they open the better.
