ZJ wheels on Patriot? - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > ZJ wheels on Patriot?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep Restorations, Mild to Wild! CCORGrizzly Lockers available at Rockridge4wd.com
Unread 03-06-2014, 09:18 PM   #1
Blk92XJGuy
1992 XJ Cherokee
I have a 98 ZJ with stock 5.9 wheels on the stock 225/75/16 tires. My ZJ tires are pretty new but I'm lifting it up and am going bigger. I have a family member who has an 07 Patriot which needs new tires pretty badly. I offered to give my tires/wheels to them if they fit. From researching, it appears the bolt pattern will be the same, correct? Now I don't know what model exactly the Patriot is. It has nice looking wheels, not the steel ones, but it's not Limited since it doesn't have fogs and the interior is plastic/cloth. I know the stock wheel size is both 16 and 17. Any ideas?
92 XJ - 7''/SeriousOffroad long arms/Bilstein 5100/Aussie/33x12.50 15x8 Kumho KL71s/plus more
98 5.9 -Monstaliner bed liner exterior - 3'' Kolak exhuast - SCT Tuner - OEM rubber cup holder insert - 52mm Holley TB - Complete audio upgrade
Blk92XJGuy is offline   Reply With Quote
Unread 03-07-2014, 06:04 AM   #2
Blk92XJGuy
1992 XJ Cherokee
Bolt pattern is the same and the wheels are similar in size. Should be fine right?
Unread 03-09-2014, 03:28 PM   #3
cherox
2012 KK Liberty
Yup, and would love to see it, so if you do it, please take and post pictures!
cherox is online now   Reply With Quote
