Windshield Fluid? - JeepForum.com
post #1 of 3 Old 04-18-2010, 10:20 AM Thread Starter
jandyrodax
2007 MK Compass
Windshield Fluid?
We have a 2007 Jeep Compass.
Back in January we got our normal oil change done and a few hours later I went to use the wiper fluid and it was barely (if at all) coming out. It was working great before then. Now the wiper fluid doesn't come out at all.
We probably should have taken it back to the oil change place (which is now 2 hours away since we have moved) to have them look at it since the did add more fluid and it was working fine prior to the oil change. My husband says he will take a look at it but with him being an over the road truck driver he's not really had the time to look at it yet.
With this pollen it's driving me nuts not being able to clean my windshield.
Anyways, how can I check to see if it's clogged or if it's something else causing the problem?
jandyrodax is offline
post #2 of 3 Old 04-18-2010, 10:49 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Do your wipers still work? If they do then hopefully the multi switch lever plug is still connected. This would really be a fluke if it wasn't, just checking.
The windshield fluid reservoir is the one that's closest to the passenger side fender. Look down in front of it and you'll see the upper electrical connector, make sure it's seated. Below that is where the hoses connect, make sure that they are still attached/not leaking. Then follow the hoses up on the passenger side to the underside of the hood and make sure that they are attached and that you have no leaks. If you don't find any problems there then it could be the pump has quit working or there is some other electrical/wiring problem.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 3 Old 04-18-2010, 11:41 AM Thread Starter
jandyrodax
2007 MK Compass
Yes, the wipers are working just fine, just not the washer fluid.
All of the hoses seem to be in tact. I am tempted to dump the fluid out and see if there is anything in it. LOL!
If it is the pump that's gone out I sure hope it's not too expensive. I just want my water to work again. We haven't had any other problems out of the car except the power windows went out but luckily that was still under warranty when it happened...other than that everything else has been great.
compass , patriot , washer fluid , washer pump
Can you get a Windshield Tint in front of Mirror goshawk99 Jeep Compass & Patriot Forum 0 10-02-2009 06:19 AM
Jeep Compass - windshield condensation Mistyfate Jeep Compass & Patriot Forum 21 08-24-2009 10:02 PM
cracked windshield jessasfella Jeep Compass & Patriot Forum 10 04-24-2008 01:02 AM
Windshield washer? Anewbigging Jeep Compass & Patriot Forum 1 03-07-2008 05:03 PM
Frost inside windshield snood Jeep Compass & Patriot Forum 3 02-21-2008 07:31 PM
