Whistling Sound from Compass Engine when not Pressing Accelerator - JeepForum.com
post #1 of 9 Old 12-05-2007, 06:03 AM Thread Starter
jaisunihm
2007 MK Compass
Hello all. I just joined this forum to get some insight to my compass limited. I have about 12,000 miles on my compass and not so long ago i started hearing a high-pitched whistling sound from my engine when not moving or simply no pressing on the gas. Do you guys not why this sound is occurring? Some friends told me that it may simply be a nuissance sound, but nothing wrong with the engine. However, the sound is very annoying! Please advise or help if you know why this is occurring. Thanks.
jaisunihm is offline
post #2 of 9 Old 12-05-2007, 06:13 PM
Laloggia
2010 JK Wrangler
Have you replaced the radio with an aftermarket one? Sometimes this causes feedback when there is a bad ground and you can hear the engine buzzing through the car speakers.
Just an idea.
2010 Wrangler Islander
2005 Chrysler Crossfire
2010 Honda Crosstour
2007 Honda Civic Coupe
Laloggia is offline
post #3 of 9 Old 12-05-2007, 07:24 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I'd need to open the hood to hear where it's coming from. Several possibilities: vacuum leak, radio noise, alternator/water pump/AC bearings, serpentine belt and other things. It's probably not serious but I'd have the dealer take a look at it.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 9 Old 12-05-2007, 08:08 PM Thread Starter
jaisunihm
2007 MK Compass
Thanks for the replies. It sounds like it may be coming from right under the timing belt. i was informed that there is some sort of lever underneath and that many vehicles have this problem with it making the noise. I'm waiting to take the car in to the dealer, but I have to wait since one of my friends will have to drive with me to the dealer. Please do let me know if you hear anything else regarding this issue. Thanks again.
post #5 of 9 Old 12-06-2007, 03:57 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
That would be the Automatic Tensioner for the Serpentine Belt. It runs on the back side of the belt and could get a glaze built up on it that belt dressing could fix or it may be the bearing. Either way let the dealer look at it.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #6 of 9 Old 12-06-2007, 05:59 AM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
Its the supercharger in there honestly! A guy at work with a Dakota has a problem with his harmonic balancer and you can only hear it at idle.
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #7 of 9 Old 12-06-2007, 07:54 AM Thread Starter
jaisunihm
2007 MK Compass
I'm going to try get in in the dealer as soon as possible. Thanks for the suggestions. At least now I know what the possible problems may be.
post #8 of 9 Old 12-15-2007, 08:54 AM Thread Starter
jaisunihm
2007 MK Compass
Sound fixed
Gramps, the problem that was causing the whistling sound was that there was a leak from the water pump. Originally, the dealer didn't do anything to it. I took the car around the block and the sound came right back. They took a look at the car again and said the water pump was the issue. They replaced all the parts and now the sound is gone. Thanks for the advise.
post #9 of 9 Old 12-15-2007, 09:15 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It sounds like it had a leak at the seal in the wp and after heating up the pressure caused the whistle. That's a hard one to find sometimes because if there is no noticable water leak you don't normally look at the wp. Glad that you found it.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
Part-Throttle Whistling, Beep? b1llyw Jeep Compass & Patriot Forum 3 09-21-2009 03:45 PM
Engine coolant compass plunderisley Jeep Compass & Patriot Forum 5 02-26-2009 05:14 PM
Compass Engine Break In lmulli1966 Jeep Compass & Patriot Forum 2 12-12-2008 03:48 AM
07 Compass with BA sound...jvc HU problems.. evillilsf Jeep Compass & Patriot Forum 8 03-17-2008 05:28 PM
Compass Reviews - solutions to common Compass "problems" eighteenwheeler Jeep Compass & Patriot Forum 8 06-08-2007 06:32 PM
