where to add fluid 2011 patriot - JeepForum.com
post #1 of 1 Old 08-12-2014, 08:58 AM Thread Starter
umwolvefan
2011 patriot front wheel drive ,front driver side ball joint was replaced.... when control arm was disconnected from wheel to press out ball joint, the wheel was turned to press out ball joint, some fluid leaked out around axle at case.....need to locate fill plug.....any help would be appreciated... thank you
umwolvefan is offline
