When driving lights 4WD! - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > When driving lights 4WD!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRubicon Express Suspensions from CCOR 706-207-4140Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955
Unread 01-18-2014, 01:24 PM   #1
rsaspid
I have a patriot in 2007. While driving lights 4wd! Rear-wheel drive is disconnected. Please help.
rsaspid is offline   Reply With Quote
Unread 01-18-2014, 03:20 PM   #2
aroundincircles
1989 XJ Cherokee
The most common issue is there is something stuck around the switch that you pull up on, keeping it up in a locked position, other than that, there are some wires the the tunnel that get corroded.
1989 Cherokee Pioneer
http://goo.gl/h3lf9 youtube channel.
aicoffroad.com
aroundincircles is offline   Reply With Quote
Unread 01-19-2014, 12:21 AM   #3
rsaspid
I would like to know more specifically about my problem, if possible.
Unread 01-19-2014, 01:42 PM   #4
aroundincircles
1989 XJ Cherokee
Then provide more details, What have you done to troubleshoot, what have you looked at? I suggested one option, based off your lack of information.
aicoffroad.com
Unread 06-30-2014, 05:34 AM   #5
rsaspid
When connecting the scanner issues an error C1078 TIRE REVOLUTIONS RANGE performance. What could it be?
Unread 07-01-2014, 09:27 AM   #6
JeepCares
Have you changed tires recently?
First of all, check to see if the tire/wheel sizes match and are at the correct tire pressure.
Lee
U.S. Top Care
Chrysler Group LLC
JeepCares is offline   Reply With Quote
Unread 07-01-2014, 03:19 PM   #7
tjkj2002
2002 KJ Liberty
Yep mis-matched tires.
If your tires are more then 3/32" tread depth difference and/or different make/model of tire can cause your issue.
That means if you have Goodyears on the front and BFG's on the rear,even if the same labeled size,will actually be different sizes.And again a tread depth difference in same make/model tires from front to rear can also cause this issue.
tjkj2002 is offline   Reply With Quote
