What are your RPM's @ 70 MPH? - JeepForum.com
Go Back JeepForum.com > Models > Compass & Patriot Forum > What are your RPM's @ 70 MPH?
IRON CROSS Jeep JK Front and Rear STUBBY BUMPERS IN STOCK Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Jeep speedometer gears at rockridge4wd
Unread 04-11-2008, 03:34 PM   #1
UTAH
Khaki Patriot 4x4 Ltd. w/FDII
I'm curious about any gearing differences between the models (Compass, Patriot, 4x4, stick and auto).
I'm running exactly 3,000 RPM's at 70 MPH*. That's about 113 KPH for our metric-based friends.
* Speed verified
Bill
2013 JK Sahara 2-dr, 6 speed
2014 KL Cherokee Trailhawk
UTAH is offline   Reply With Quote Quick reply to this message
Unread 04-11-2008, 04:30 PM   #2
davep
2007 MK Compass
Seems high, I was just on the freeway going 70ish and I don't think I ever saw my RPM exceed 2500 while using cruise control. Maybe even lower than that. Compass CVT2 4x4
davep is offline   Reply With Quote Quick reply to this message
Unread 04-11-2008, 04:42 PM   #3
UTAH
Originally Posted by davep View Post
Seems high...
Yes - that's why I'm curious. Yours @ 2500 is about where I thought I'd be. Heck, my JK runs 2300 RPM's @ 70.
Is it because of the FDII?
Bill
Unread 04-11-2008, 05:38 PM   #4
Argent33
2014 JK Wrangler
I think my Compass 4x4 5-Speed runs about 3000rpm at 70
~Paul
-[O l l l l l l l O]- 2014 Freedom Edition JKU - Hydro Blue 6-Spd
Argent33 is offline   Reply With Quote Quick reply to this message
Unread 04-11-2008, 05:42 PM   #5
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
FD II's are geared lower and yours sounds about right UTAH.
CVT's are:
FDII is 3.21:1
FD I is 2.41:1
5 Spd is 3.33:1 (I've seen a report that this may have changed in '08.)
Going with a taller tire will help a little and of course slowing down, but that may be hard to do in if you want to keep from getting run over.
Bob
MK Skid Plate fasteners for sale posts 68 & 69
Also visit me at Photobucket
Gramps is offline   Reply With Quote Quick reply to this message
Unread 04-11-2008, 06:48 PM   #6
UTAH
Thanks. Good info.
The engine does seem right in the groove at 3,000 RPM's, it's smooth and still has plenty of headroom. And, it does not seem to be hurting MPG (which was @ 22.5 for the first tank). I figure I'll probably get around 24 MPG once it breaks in. It's just revving higher than I'm used to.
Bill
Unread 04-11-2008, 07:37 PM   #7
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
That's not bad at all for an FD II! Are you going down hill both ways?
Bob
Unread 04-11-2008, 07:53 PM   #8
UTAH
Awww... just using the cruise as much as possible and driving relatively sanely.
Bill
Unread 04-14-2008, 08:00 PM   #9
Elihawk
2008 MK Compass
My compass
at 70 was running 2,5-2,600 rpm...when I hit 3,000 rpm, I was doing 78
Elihawk is offline   Reply With Quote Quick reply to this message
Unread 04-14-2008, 08:42 PM   #10
Snowplow
My rallye with the 5 speed manual runs at 2300 to 2500 rpms at 70
Snowplow is offline   Reply With Quote Quick reply to this message
Unread 04-16-2008, 12:34 PM   #11
Urr
CRD with the 6 speed manual runs with a bit more than 2400 rpms at 70.
Happiness is not a goal, but a lifestyle
Ex 2007 Jeep Compass Sport 4x4 CRD in action :)
DD 2011 Mitsubishi ASX Invite 4WD DiD
In bright and happy future: Jeep Wrangler
Urr is offline   Reply With Quote Quick reply to this message
Unread 04-16-2008, 01:43 PM   #12
Argent33
2014 JK Wrangler
Hmm wonder how come my Rallye 5 Speed runs higher....
~Paul
Unread 04-16-2008, 02:02 PM   #13
Urr
Absolutely it does, but relatively not...
Diesel's "red zone" begins @ 4500, your's may-be at @ 6000?
Unread 04-16-2008, 02:52 PM   #14
steel5blue
2007 MK Compass
So does mine (about 3000+ rpm at 70). They must have changed the gear ratios on the 2008 5-speed.
Can any other 07 and 08 5-speeders chime in?-
Rav-who? CR-what? Arizona-where?
2007 Compass Sport Steel-5speed-Blue 4X4
steel5blue is offline   Reply With Quote Quick reply to this message
Unread 04-16-2008, 03:32 PM   #15
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It looks like the final drive ratio on the 5 speed went from 4.12 in '07 to 3.91 in '08. Here's the '08 specs:
http://www.jeep.com/en/2008/patriot/# Features and Specs, Technical Data.
Assuming they kept the same trans ratios:
1st - 3.77
2nd - 2.16
3rd - 1.41
4th - 1.026
5th - 0.81
Transaxle Ratio - 4.12 ('07); 3.91 ('08)
This calculates out to 15.53:1 in low and 3.33 in high for '07; 14.74 in low and 3.16 in high for '08.
Bob
