Underhood switched 12V 2012 Patriot - JeepForum.com
post #1 of 4 Old 06-26-2012, 08:25 PM Thread Starter
bburkett
Can anyone tell me where I can cleanly and easily connect to switched 12V under the hood of my 2012 Patriot Limited? I could get it out of the power module (fuse box) under the hood, but I would have to cut into the housing. I am hoping there is an open connector available.
I need to power a relay when the ignition switch is on acc or run.
Thanks,
Bob
bburkett is offline
post #2 of 4 Old 06-27-2012, 04:24 PM
dirkdiggler106
2012 MK Patriot
Thanks,
Bob
Just run a wire into one of the fuse boxes and use something like this:
(they make them for most kinds of fuses)
look in the manual or maybe a service manual to find a free spot that has switched power... or play around with a test light. Or choose something that wouldent be adversly affected like the power point fuse...
Good luck!
RIP MY JEEPS... 1998-TJ 1992-XJ 1999-TJ 1994-XJ 1998-ZJ... All were lifted and locked...
dirkdiggler106 is offline
post #3 of 4 Old 06-29-2012, 07:30 PM Thread Starter
bburkett
The fuse box cover under the hood has a weatther-proof seal on it and I would have to cut or drill in to it...
I am still searching for a good point to tap in to existing wire... brand new (only 1200 miles) so I want to be careful where I tap in..
Thanks,
Bob
bburkett is offline
post #4 of 4 Old 06-30-2012, 10:55 AM
FujativeOCR
2011 MK Patriot
What are you Installing again? Is the relay the only thing being powered? I'm just thinking that if you tap into an existing circuit it will increase the load on that circuit. The existing fuse might not be enough then.
FujativeOCR is offline
Purchasing a 2012 Patriot! goombatommy Jeep Compass & Patriot Forum 31 07-26-2012 10:42 AM
Considering a 2012 Patriot... audiodrive Jeep Compass & Patriot Forum 13 03-30-2012 09:05 AM
2012 jeep patriot rfslonski Jeep Compass & Patriot Forum 1 12-19-2011 04:45 PM
2012 Compass/Patriot changes IRSmart Jeep Compass & Patriot Forum 0 06-06-2011 03:31 PM
Patriot and Compass to be 1 vehicle by 2012 unclejjg Jeep Compass & Patriot Forum 15 03-14-2009 06:27 AM
