turn signal blinks faster than the other with headlights on - JeepForum.com
post #1 of 6 Old 11-11-2009, 05:47 PM Thread Starter
VolunTold
2009 MK Patriot
my 2009 patriot right turn signal blinks faster than the left only with the headlights on. blinks normal with headlights off. the car is brand new with only 4000 miles on it
VolunTold is offline
post #2 of 6 Old 11-11-2009, 06:32 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
VolunTold - I moved your post here from the Grand Cherokee forum to the Patriot Forum
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 6 Old 11-13-2009, 05:03 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
I can't come up with a good answer for this other than "it's electrical", duh. Maybe your blinker fluid is low?
I could suggest re-seating all of your fuses - easy; and re-seating the connectors in the TIPM - a real PITA, and seeing what happens.
How fast is fast? 2x?
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 6 Old 11-16-2009, 10:14 AM
PurpleHayes
2008 MK Compass
Actually sounds like a grounding problem. I once had something similar going on along with several other electrical symptoms with an old Chevy Astro I had. It took the mechanic about 15 minutes to find it and no parts charge!
PurpleHayes is offline
post #5 of 6 Old 11-16-2009, 10:15 AM
PurpleHayes
2008 MK Compass
Ha! Blinker fluid...I'll be using that one. :-)
post #6 of 6 Old 11-16-2009, 05:10 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
True. I had a rusty socket that caused problems too. It's not an uncommon problem with boat trailers either. Not that you should be seeing much rust on a newer vehicle but it's all part of the ground that completes the circuit.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
Compass headlights Ibeta Jeep Compass & Patriot Forum 21 10-17-2009 04:23 PM
Replace Left Turn signal lens shannonmundy Jeep Compass & Patriot Forum 2 09-03-2009 01:30 PM
2007 compass turn signal bg252525 Jeep Compass & Patriot Forum 1 05-23-2009 02:17 PM
Getting VSS signal in non-premium system Compass rob_rector Jeep Compass & Patriot Forum 0 03-20-2008 09:50 AM
keyless enrty and headlights CharBroiled Jeep Compass & Patriot Forum 11 09-20-2007 03:15 PM
