Transmission needs replaced - JeepForum.com
post #1 of 10 Old 09-03-2008, 03:07 PM Thread Starter
mashnost
We've been feeling and hearing a "flutter" in the transmission of our 2007 Compass at about 40mph, we took it to the dealership and they told us that it will need a new transmission! At least it's covered under warranty but this shouldn't be happening at 26,000 miles! It also needs a new windshield wiper motor since the high setting wouldn't work... Anyone else having the same problems?
mashnost is offline
post #2 of 10 Old 09-03-2008, 03:29 PM
festerw
festerw's Avatar
CVT or 5 speed?
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is offline
post #3 of 10 Old 09-03-2008, 05:25 PM Thread Starter
mashnost
it's a CVT. We have to wait a week to get a new transmission shipped. Dealer told me that since it is a sealed system, they just replace the whole thing...not bad if you're under warranty, which I am!
mashnost is offline
post #4 of 10 Old 09-04-2008, 03:47 AM
festerw
festerw's Avatar
Hmm, I was just wondering because I don't recall hearing about any other failed CVT's sorry for your bad luck. The 5 speed on the other hand I've heard quite a few horror stories about.
festerw is offline
post #5 of 10 Old 09-13-2008, 09:18 PM Thread Starter
mashnost
Well, we got the transmission replaced....and the flutter and noise was still there...the service manager said that I might want to go check the tires since I had to replace 2 tires (one had a nail in the sidewall) about 2 months ago...I bought 2 more matching tires and voila, the noise went away...why didn't they check this in the first place? I didn't know that I needed to replace all 4 tires on an AWD vehicle at the same time! The transmission was covered under warranty but I can't help thinking that a transmission was completely unnecessary.
mashnost is offline
post #6 of 10 Old 09-14-2008, 09:03 AM
Zappy
2007 MK Compass
I would hope that before any dealer would recommend replacing the transmission that they would really check it's condition instead of just saying it sounds like you need a new tranny and replace it like that. Did they say if they found any real evidence of transmission problems before they just changed it out?
Zappy is offline
post #7 of 10 Old 09-14-2008, 11:10 PM Thread Starter
mashnost
Nope, I really think that they messed up and replaced the transmission without it needing it. When I first brought it in, they told me that they couldn't find anything wrong with it but that it was definitely making a sound and they could also feel the flutter, so they said it was probably internal and it would need a new transmission...Their mistake, my new transmission at 28000 miles.
mashnost is offline
post #8 of 10 Old 09-15-2008, 08:06 AM
Jawa78
2008 MK Compass
Two things I learned from having a 99Limited WJ
1. Unless the tires are brand new you do not replace one or two tires you replace all 4.
2. Unless you mark your tires before going in for rotation the dealership or tire place will not rotate them properly. Most places are lazy and tend to do front to back rotation vs cross rotation.
AWD and 4x4 jeeps and cars are just plan picky when there is un even tread .
Jawa78 is offline
post #9 of 10 Old 10-01-2008, 11:25 PM
wil3284
so was your tranny making like a metal clanging/ clunking sound also because i have a 07 compass and mine started doing that at about 10k miles and i was wondering about that myself it kind of scares me. i just dont want to be left on the side of the road. and did they give you a rental because this is my and the wifes only car right now.
1993 YJ 5.0, 1983 CJ5, 2007 Compass Rallye, 1993 Cherokee, 2002 VW GTI
You tube vid of my wrangler finally running
need reptiles?
wil3284 is offline
post #10 of 10 Old 10-03-2008, 07:03 AM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
Mine makes a clunk when the clutch or whatever it is in the CVT disengages.
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
TSB 21-011-08: Manual Transmission - Bad Synchros Dr. Grinch Jeep Compass & Patriot Forum 35 03-02-2010 09:36 PM
Anyone here with transmission problem? I have a CVT2 Beware Jeep Compass & Patriot Forum 1 04-30-2009 06:23 AM
Transmission Cooler Cobydick Jeep Compass & Patriot Forum 2 10-18-2008 04:27 PM
Patriot 4x4 2008 transmission f_chabot Jeep Compass & Patriot Forum 3 09-07-2008 07:36 AM
continously variable transmission??? taseal Jeep Compass & Patriot Forum 4 02-08-2008 12:46 PM
