Trans Overheating - Page 3 - JeepForum.com
post #31 of 43 Old 09-07-2013, 08:56 AM
Woodzy24
Originally Posted by FujativeOCR
And dont forget to leave bad reviews for the other dealer everywhere you can find. Yelp etc.
Jeep reckon it is the crank sensor. Will find out on Monday if the problem is resolved.
Woodzy24 is offline
post #32 of 43 Old 09-07-2013, 10:38 AM
FujativeOCR
2011 MK Patriot
You know...they put these sensors all over these new cars...and it's always the sensor itself that fails.
FujativeOCR is offline
post #33 of 43 Old 09-11-2013, 04:12 PM
taylor2384
2011 MK Patriot
Well my 2011 Patriot left me stranded 120 mile from my house again yesterday. The Jeep dealer I have been dealing with has not called me back today so I tried going to a other Jeep dealer and asked if they honor my extended warranty. He said he did and after I told him about my problem he grabbed his 'transmission specialist' and they said that they're aware of the problem and Chrysler isn't doing anything about it. They say its in the manual as 'normal'. Are you kidding me??? They even said they had someone else earlier in the week with the same problem. I can't believe that!!! I will be filing a case with Chrysler and will be buying a Toyota or Honda in the next month instead of the new Cherokee or Grand Cherokee.
taylor2384 is offline
post #34 of 43 Old 09-13-2013, 09:24 PM
tjkj2002
2002 KJ Liberty
Buy a vehicle with a real trans and not a POS CVT and you will be good.
tjkj2002 is offline
post #35 of 43 Old 09-13-2013, 09:45 PM
Woodzy24
Update on my transmission issue. Although the new dealership admit we have a problem and the first thing the guy said to us was sounds like you need a new transmission- they replaced the crank sensor and it still didn't fix the problem. Now Chrysler want them to carry out what the dealership describe as an extremely laborious investigation into the electrics rather than replace the darn thing. They even admitted off the record that it is a lousy transmission. Chrysler, however, refuse to admit that.
The dealership have promised that we won't get the jeep back until its fixed. They even admitted that not being able accelerate to get out of trouble was dangerous. We will see what happens next week. Chrysler do not fill us with confidence but at least the dealership are admitting there is a fault- even if they don't seem to be able to fix it yet.
Woodzy24 is offline
post #36 of 43 Old 09-17-2013, 05:48 PM
taylor2384
2011 MK Patriot
Hey tjkj2002 why don't you get a life instead of sitting at home on a Friday night making worthless comments to posts?
post #37 of 43 Old 10-01-2013, 12:39 PM
taylor2384
2011 MK Patriot
Update on my transmission issue. The dealer just called me and said he was working with Chrysler on the issue and their recommendation is to flush the transmission that has 80k on it. He said 'you're supposed to do it at 60k'. Yeah if you're under extreme conditions which I'm not, (not using it as a taxi, no hitch so no towing) just every day driving on the highway. So they want $400 to do that which is BS!!! I understand the fluid is expensive but they don't even know if this will fix the problem!! Why would I pay $400 to do something that is not scheduled yet and may not fix the problem?! That's the reason I purchased an extended warranty!!!!
post #38 of 43 Old 10-01-2013, 10:10 PM
Woodzy24
They replaced our transmission after testing until it broke enough for Chrysler to accept to replace it under warranty. We had to wait for over a week to get the part as there were no parts in the north America or mexico. So far so good. Dealership did a great job- except following up with us for trade in which we want at some point. We will change it before the warranty is up for sure. Glad to have it back.
Woodzy24 is offline
post #39 of 43 Old 10-13-2013, 09:51 AM
carlsonr
had same problem. used same fix as my dodge turbo cummins transmission. All Chrysler products have a mechanical thermostat built into the oil-air cooler line. its made of aluminum so when the spring and plunger get gritty it doesn't move when it heats up and sends your fluid right back into the transmission uncooled. it simple to clean, remove snap ring pop out plunger and thermo spring clean off grit replace don't misplace o-ring. on a patriot follow your oil-air cooler lines through the grill and it will be inboard of the driver side headlight. it is a square 3x3 inch aluminum block with four oil lines going into it. you can just eliminate it and run full time air-oil cooling if you don't live in frigid climate. change your fluid at 60K not 120 as it will be burnt for sure by then. it cheaper online then at a dealer. 35 a gallon or 7 a quart, you need five for a oil and filter change. the cvt transmission is a very good transmission, built and sold by jatco to over a half dozen car manufactures.
carlsonr is offline
post #40 of 43 Old 10-13-2013, 10:04 AM
taylor2384
2011 MK Patriot
Carlsonr are there any special tools needed to change the transmission fluid? Do you know of any 'how to's'?
post #41 of 43 Old 10-15-2013, 06:17 PM
carlsonr
nothing special, metric socket set,reccomend cleaning your oil-air line thermostat at same time.
carlsonr is offline
post #42 of 43 Old 08-10-2016, 05:02 PM
sadpatriotowner
My jeep does this repeatedly. Did the fluid change stop your problem?
sadpatriotowner is offline
post #43 of 43 Old 08-12-2016, 06:49 PM
aroundincircles
1989 XJ Cherokee
There is a good chance if it has over heated more than a few times, you have trashed your transmission... Time to take it to a shop that specializes in cvts, and have it looked at. This same transmission is in a lot of nissans, so I would go to an independent shop that specializes in nissans.
89 Cherokee
aroundincircles is offline
Overheating 2010 Patriot 4x4 Liberty6 Jeep Compass & Patriot Forum 5 06-29-2012 09:15 AM
Going in the shop next week for Trans issue srtdodge05 Jeep Compass & Patriot Forum 1 03-21-2012 01:12 PM
Patriot Trans downshifts hard Rubes Jeep Compass & Patriot Forum 5 04-20-2011 10:21 PM
Patriot Trans / Diff svc DIY Gav'spurplez Jeep Compass & Patriot Forum 6 10-29-2009 06:55 PM
Pedal Kits for manual trans. cuemark8 Jeep Compass & Patriot Forum 1 05-17-2007 12:55 PM
