Trailer tow prep package question - JeepForum.com
post #1 of 4 Old 07-30-2014, 10:45 AM Thread Starter
mjstk
So, after owning GM products for 15 years, I am the proud new owner of an '08 Jeep Patriot. I've had my Patriot for 2 whole days now, and I'm officially hooked on Jeeps. I want to have a hitch installed, but I am having a hard time finding out if the one I bought has the trailer tow prep package installed already. I've tried searching the forum and searching the web for my VIN, but I can't seem to find anything that tells me where I can find a list of options for my Patriot. Could someone please point me in the right direction?
I plan on having the oil cooler installed if I don't have one, but it would be nice to know if I actually need one first.
mjstk is offline
post #2 of 4 Old 07-30-2014, 11:27 AM
miscrap
Do you have a full size spare tire? The tow prep package included one. Also, it came with a wiring harness do you have a 4 flat plug in back?
miscrap is offline
post #3 of 4 Old 08-01-2014, 10:15 AM
TeHpWNaG3
2007 MK Patriot
Even though I bought the tow package from the dealer up front, I still had to bring the vehicle in to have the hardware and electrical installed. YMMV.
If you have the wiring harness pre-installed, pull out the rear deck to access the spare tire. If you don't see the plug somewhere inside the compartment, they may have it tucked behind the left side panel. Facing the rear of the vehicle, pop out the left side interior panel and look for the power module and/or harness plug. All the cargo area panels comes out fairly easy. Just pull them straight back from where they attach to the body. They snap back in even easier. Some of the foam seals may have to be pulled first, so keep an eye their orientation. Some of the panels overlap, so keep an eye on which ones come out and go back in first. It's simple, but I don't want you to go in totally blind.
If you don't have the tow package electrical, honestly, I would buy them in the aftermarket and install them yourself, unless you don't feel comfortable doing any of this.
I installed the oil cooler kit myself. I don't do a lot of towing, I like neat options like this, so I installed it. It will make your coolant temp run a little warmer, but I think the intended benefits are there. It's up to you on whether or not you actually need it.
TeHpWNaG3 is offline
post #4 of 4 Old 08-01-2014, 12:09 PM Thread Starter
mjstk
Thanks! I was just about to ask where I could find the wire harness. I will check that out.
mjstk is offline
