TPMS light on - JeepForum.com
post #1 of 11 Old 12-28-2009, 02:57 PM Thread Starter
Elihawk
2008 MK Compass
TPMS light on
My tire pressure light came on a couple of weeks ago. Twice, I have checked and adjusted the tire pressure, but noted no low (or high) tire pressures. I had an identical problem when it got cold last winter. Anyone else have this problem? Faulty TPMS sensor or something? Thanks
Elihawk is offline
post #2 of 11 Old 12-28-2009, 03:03 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It could be a faulty sensor. What pressures are you running?
http://www.jeepforum.com/forum/f98/tpm-sensors-741251/
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 11 Old 01-05-2010, 01:20 PM
RW33
2008 MK Patriot
Our 2010 Patriot (company car) with 1800km/1000mi has a similar issue. I've added air twice in that time. We had an 08 temporarily and it had the thing. That one needed air every 5-6 days on 2 or more tires...and not always the same tires. The pressure was down to 205kPa on all 4 tires. s/b 235kPa. Equal to about a 5psi difference. We'll be taking it back to the dealer to see what they say.
"You Can Run, But You Can't Hide"
Lord Humungus
RW33 is offline
post #4 of 11 Old 01-05-2010, 01:32 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
In that case I'd say the sensors were doing their job. It sounds like a leak in the tire or valve stem could be the problem and not the sensors.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 11 Old 01-05-2010, 01:55 PM
miketmx
2015 MK Patriot
Around Calgary the temperature can vary from 40 above zero farenheit to 30 below zero and in a matter of hours. I try to keep the tire pressure around 35 lbs Cold and let it drop to 31 lbs when way below zero. Ignorance is bliss with my steel wheels without sensors for the winter tires but I didn't have any rim leaks or valve leaks with any of the 8 wheels for the Patriot.
miketmx is offline
post #6 of 11 Old 01-05-2010, 02:06 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Yes, I did forget temperature changes quickly in some areas. I've been between -3 and 17 F for the last couple of weeks. My Kumhos are pumped up to 38 normally.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #7 of 11 Old 01-06-2010, 09:25 PM
cactus_jack
sometimes, Fix-a-flat will ruin the sensors too. My poor old dad made that mistake twice on his car, drives him crazy when I have to drive to his house just to tell him not to do dumb things
CACTUS_JACK
98 XJ Sport Budget Build
cactus_jack is offline
post #8 of 11 Old 01-09-2010, 08:42 PM
RW33
2008 MK Patriot
Leaks...to almost equal pressure...on all 4 tires still seems mighty odd. The previous Patriot had 1 tire.
Lord Humungus
RW33 is offline
post #9 of 11 Old 01-09-2010, 08:47 PM
COLOUXJ
2010 JK Wrangler
it is probably a bad sensor, they go bad and are fairly easy for a shop to replace, very difficult to do on your own.
COLOUXJ is offline
post #10 of 11 Old 01-09-2010, 09:19 PM
InfernoGirl
It will come on due to the change in air temps.... Cold air takes up less room. If your tires all read accurate pressure, don't worry about it. Especially if the light goes out when the tires warm up.
Dirty Mudder seat covers/Steering column covers/spare tire covers
Like my Dirty Mudder FB fan page here:
01 Jeep Wrangler Sport 4.0L, auto
Mine
07 2D Rubicon Flame Red His
InfernoGirl is offline
post #11 of 11 Old 01-10-2010, 05:30 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
The rule of thumb is for every 10° Fahrenheit change in air temperature, your tire's inflation pressure will change by about 1 psi (up with higher temperatures and down with lower).
Also remember that the sticker on the door is for MINIMUM COLD air pressure and that the MAX air pressure is on the tires themselves. Try filling them up cold 1/2 way between the 2 extremes and see what happens. If this cures the problem then you may want to adjust the pressure for ride comfort, handling, etc.
If you go to the link in post #2 you'll find that member was getting interference from his I-phone charger.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
Compass TPMS - replacements, and how to install? plunderisley Jeep Compass & Patriot Forum 5 03-08-2009 10:20 AM
TPMS Sensors Matthew1785 Jeep Compass & Patriot Forum 8 07-22-2008 10:31 AM
TPMS on a euro pat keithark Jeep Compass & Patriot Forum 1 06-30-2008 05:11 AM
TPMS on Compact Spare? CoriolisSTORM Jeep Compass & Patriot Forum 15 06-06-2008 04:50 PM
Tire Pressure (TPMS) jasper1022 Jeep Compass & Patriot Forum 5 03-02-2008 09:40 AM
