tire pressure warnings - JeepForum.com
post #1 of 9 Old 09-18-2007, 09:20 AM Thread Starter
Bockwinkle
My wife has told me that for the last 3 mornings (the overnight temperature has finally dipped down into the high 30's) she has gotten a low tire pressure alarm right after starting the vehicle. After driving a few miles (and tires warming up) the alarm goes away. Under normal operation the tires display around 35 psi
Sooooo.....should I add a pound of pressure (incrementally each morning until the alarm stops) to try and eliminate the low tire pressure at cold temps but hopefully still remain in normal pressure range once the tire warms up?
any ideas?
Bockwinkle is offline
post #2 of 9 Old 09-18-2007, 10:50 AM
Coasty161
our low pressure warning goes off at 25-28psi i keep tires at about 30. when warmed up they are at about 34-35psi.
Coasty161 is offline
post #3 of 9 Old 09-18-2007, 11:29 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
It happens every time I get a nail in my tire. But it's only low on one tire. If yours are all the same pressure just pump them up a little. I try to keep mine at 35 lbs cold.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #4 of 9 Old 09-18-2007, 02:14 PM
Jason31
35 PSI after the tires have warmed up is perfect. I would not adjust them at all. 35lbs cold is too much air and will negatively affect the life of the tire.
2007 Jeep Compass Limited - Black w/Chrome 18" OEM Wheels
Jason31 is offline
post #5 of 9 Old 09-18-2007, 02:40 PM
merlinTec
merlinTec's Avatar
Hi
Read the label on the door and in the handbook this states COLD pressure recommendation at 35 psi and that is what they should be when COLD, if they are lower then recommended threshold the warning light will come on. So yes put some air in.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #6 of 9 Old 09-19-2007, 08:34 AM
Jason31
I should have noted in my comment above that the size of wheels you have makes a difference here.
Jason31 is offline
post #7 of 9 Old 04-01-2012, 09:40 AM
somers
2010 MK Patriot
Tire pressure
Stock Jeep Patriot 2010 Wheels are 17 " the tires Continental 215- 60 -17.
Referring to Continental web page for my specific tire they say 40 psi for driving around town
35 psi cold for out on the highway.
at 40 psi i do not notice any lack of vehicle comfort
Under inflation will cause the edges of the tire to wear pre maturely during slow speeds..
Don't forget the spare PSI.
I keep mine at 42 Psi because it is difficult to recover from the tire / wheel well
somers is offline
post #8 of 9 Old 04-01-2012, 01:19 PM
miketmx
2015 MK Patriot
I keep my tires at 35 lb cold and I get rough riding with more than that. I think 40 or 42 lbs is the Maximum and not the recommended tire pressure.
miketmx is offline
post #9 of 9 Old 05-22-2014, 03:49 PM
somers
2010 MK Patriot
I have since reduced my tire pressure to 38 psi from 40 psi For round Town driving.
somers is offline
Tire Pressure Gav'spurplez Jeep Compass & Patriot Forum 12 05-31-2014 06:23 PM
Too much tire pressure on riot? burrell9 Jeep Compass & Patriot Forum 8 03-29-2009 12:07 PM
Tire Pressure Monitoring System Question Kev M Jeep Compass & Patriot Forum 37 11-20-2008 08:08 PM
Tire Pressure (TPMS) jasper1022 Jeep Compass & Patriot Forum 5 03-02-2008 08:40 AM
Tire Pressure Monitoring System echocat22 Jeep Compass & Patriot Forum 6 01-08-2007 09:39 PM
