Tire Pressure (TPMS) - JeepForum.com
post #1 of 6 Old 03-01-2008, 10:45 PM Thread Starter
jasper1022
I just bought my Jeep Compass yesterday and the tire pressure light stays on. I checked the pressure in the tires and they were fine. The dealer assured me that this is normal with jeeps in the winter and the light stays on due to the oxygen in the tire contracting. Can anyone attest to this?
jasper1022 is offline
post #2 of 6 Old 03-02-2008, 12:46 AM
patrick3319
2008 MK Compass
the dealer put nitro in my tires when I bought it...and haven't seen the light at all...so nothing I can say to that really...although it does seem odd!
patrick3319 is offline
post #3 of 6 Old 03-02-2008, 04:04 AM
merlinTec
merlinTec's Avatar
Hi
No the light should not be on. Was the pressures low when you checked them? What have you got them set at? You may need to over inflate them first to wake up the sensors then drop them back down.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #4 of 6 Old 03-02-2008, 07:35 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Here is an "Information Only" TSB to better help understand the system. Most, if not all, of the door placards on the MK's say 35 psi (cold). See if this helps.
http://www.wkjeeps.com/misc/Caliber/...er_2200406.pdf
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 6 Old 03-02-2008, 09:15 AM Thread Starter
jasper1022
The placards have a psi of 32 and when I checked the pressure it was indeed 32. However, I do not think the tires were completely "cold". I guess I have to work with it.
Gramps - thanks for the link. It was informative.
post #6 of 6 Old 03-02-2008, 09:40 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
You're welcome!
Just a side note: The last time that I actually had to put air in my tires it was -11 F, 35 lbs cold. Now that we are finally getting above +20 to +25 the pressure was up to around 45 psi and it was riding so rough that I thought that I had thrown off some wheel weights. That is until I realized that it was fine in the mornings (7 F) and only rough in the afternoon (20 F). I dropped my pressures down to about 32 psi cold and it's back to a good ride again. Just something that a lot of folks may want to check now that Spring is returning to the Snow Belt.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
tire pressure monitor problem on Compass jeepsternj Jeep Compass & Patriot Forum 23 08-01-2017 01:10 PM
Tire Pressure Gav'spurplez Jeep Compass & Patriot Forum 12 05-31-2014 07:23 PM
tire pressure warnings Bockwinkle Jeep Compass & Patriot Forum 8 05-22-2014 04:49 PM
Too much tire pressure on riot? burrell9 Jeep Compass & Patriot Forum 8 03-29-2009 01:07 PM
Tire Pressure Monitoring System echocat22 Jeep Compass & Patriot Forum 6 01-08-2007 10:39 PM
