Tire Pressure Monitoring System - JeepForum.com
post #1 of 7 Old 01-08-2007, 07:13 AM Thread Starter
echocat22
2007 MK Compass
whomever has the tpms, are you able to get all tires to register/have the same pressure mine say start out at 35 and 3 tires end up going to 37 and one stays at 36
echocat22 is offline
post #2 of 7 Old 01-08-2007, 08:03 AM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
That's just normal fluctuation. Mine NEVER quite read the same. 1 or 2 pounds either way is fine. You would have to set them all with a digital gauge to get the same readings but then they would start to vary depending on how many turns that you make in the course of your driving. The fronts would tend to build a little more pressure because they "squirm" on turns and corners. I have found out that it will tell you that you have a slow leak from a nail in your tire because of an unusual pressure drop.
The system only "monitors" the pressure, it is not a substitute for maintenance.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #3 of 7 Old 01-08-2007, 06:49 PM Thread Starter
echocat22
2007 MK Compass
all 4 start out at 35 , back tires and front right go to 37 and front left gets to 36, pretty much stays there
post #4 of 7 Old 01-08-2007, 07:10 PM
Gramps
The Necessary Evil
Gramps's Avatar
2007 MK Compass
Sounds 'bout like mine. You can't tell if it's 35.0, 35.5 or 35.9 psi but, it will take longer for the 35.0 tire to heat up to 36 or 37 than the tire that's at 35.9; so you'll have some variation.
Bob
posts 68 & 69
Also visit me at
Gramps is offline
post #5 of 7 Old 01-08-2007, 07:28 PM Thread Starter
echocat22
2007 MK Compass
thanks for the input gramps
post #6 of 7 Old 01-08-2007, 08:31 PM
g3cko
2011 JK Wrangler
yeah mine kinda vary too.
g3cko is offline
post #7 of 7 Old 01-08-2007, 10:39 PM
BuzzDog
I've actually noticed that if the sun is shining on one side of the vehicle, the tires on that side will register one or two pounds higher, since air expands as it is heated. I may actually have my tires filled with nitrogen...my brother-in-law has a tire shop and he'll do it for free. Supposedly nitrogen expands and contracts less with temperature fluctuations.
BuzzDog is offline
Tire Pressure Gav'spurplez Jeep Compass & Patriot Forum 12 05-31-2014 07:23 PM
tire pressure warnings Bockwinkle Jeep Compass & Patriot Forum 8 05-22-2014 04:49 PM
Too much tire pressure on riot? burrell9 Jeep Compass & Patriot Forum 8 03-29-2009 01:07 PM
Tire Pressure Monitoring System Question Kev M Jeep Compass & Patriot Forum 37 11-20-2008 09:08 PM
Tire Pressure (TPMS) jasper1022 Jeep Compass & Patriot Forum 5 03-02-2008 09:40 AM
