Tire Pressure - JeepForum.com
post #1 of 13 Old 10-30-2007, 08:01 AM Thread Starter
Gav'spurplez
Tire Pressure
OK,
so my g/f purchased a patriot and it came with the smaller 16 " wheels. well one of the add-ons from the dealer that we got in the deal were the 17" wheels and white lettered tires. i have noticed her outer tread starting to get feather a bit. 2 tires were at 30.5 and 2 tires were at 31.5.
since the jeep was built with the smaller tires, that is the "pla-card" on the inside of the door. 35 psi per tire, but that's for the 16s.
can someone tell me what the 17" white lettered tires should be set at ??
thanks
1998 Camaro Z/28
1 of 95 in Bright Purple Met.
Basic bolt-ons and 17in DRs.
1999 Wrangler Sport - SOLD
2009 Nissan Frontier Pro-4X
Gav'spurplez is offline
post #2 of 13 Old 10-30-2007, 08:38 AM
TeHpWNaG3
2007 MK Patriot
It all relative...
...to her driving style. I wouldn't let them get below 35psi or the ride becomes too mushy in the turns. I experimented with different pressures and found that 30psi, while being very comfortable taking road bumps, made the Patriot feel boat-like switching lanes and such. You don't want that feeling in an SUV!
I run them at 40psi. I get a few more miles to a tank-full and the cornering is much improved. Ride quality suffers just a tad, but I think the trade-off is more than worth it. The contact patch at 40psi is still rather large, as is the "radial bulge".
TeHpWNaG3 is offline
post #3 of 13 Old 10-30-2007, 09:25 AM Thread Starter
Gav'spurplez
how many miles do you have on yours ?? at 40 psi, do you see any " more than normal" wear in the middle of the tread pattern ??
i bumped her up to 34 psi before she left and i guess i'll re check at the end of the week. BUT she drives "normally" she definitely does not hot rod around, or take corners at 80 mph.
so, i guess we'll see
thanks
1998 Camaro Z/28
post #4 of 13 Old 10-30-2007, 10:35 AM
TeHpWNaG3
2007 MK Patriot
First off, unless the wheel camber is incorrectly adjusted or other extemporaneous circumstances are in play, the outside tread removal is evidence of pressures too low for "safe driving". Other variables need to be considered, but this IS a brand new vehicle.
I have just over 3,000 miles put on it. As I said, the contact patch at 40psi is still rather large and I have not noticed any unusual tread wear so far. My Stratus R/T has low-profile high-performance tires that tend to crown with higher pressure, but the off-road tires on my Patriot do not seem as susceptible to this phenomenon (most likely due to higher volume). Visually, it's tough to tell the difference between 35psi & 40psi. Driving them definitely tells the tale. 44psi (max spec) was a little too jittery in straight-line driving and I could feel Lincoln's beard when driving over a penny.
I do not beat on it in the turns or otherwise--because I know this isn't a sports car. I don't mind the "truck-like" feel of higher pressures (road noise, bumps, etc.). If it feels good for her to run 34-35psi, I say go for it. But I have to emphasize that running anything lower than that will degrade your fuel economy (not so much) and handling characteristics (much more so). Try 38-40 psi. You can always reduce the pressure if she feels it is too harsh. The change could be so subtle that she wouldn't even notice, but I certainly did! The fuel savings alone should be enough incentive to give it a try.
One other thought... make sure your gauge is accurate. I am big into mountain biking, where tire pressure is a HUGE deal. I use a very high-quality pressure gauge. The on-board gauge for most gas station compressors are terrible. I had a reading of 55psi at my local fill station when it was actually 35psi. So, make sure this isn't a contributing factor to premature tire wear.
post #5 of 13 Old 10-30-2007, 11:19 AM Thread Starter
Gav'spurplez
thanks for the info, when i see the patriot here at my house ( where all the tools and resources are ) i'll be sure to bump up the tires to about 38 and see if she says anything from there. she's not one to really notice stuff like that and i really have not driven it, sooooooooooooo
thanks again for your info and experiences,
1998 Camaro Z/28
post #6 of 13 Old 04-03-2012, 10:13 AM
somers
2010 MK Patriot
thanks
I run my Patriot tires 215 / 60 /17 at 40 psi because the web page of Continental says 40 for around town and 35 for the highway.
35 could eat away at the side walls.
When using a pencil tire pressure device with the sliding bar always hold the device in the vertical plane so that the slider traverses up
holding the device in the horizontal plane may give incorrect readings.
You all know that tires should be cold for the readings to be correct and the vehicle should be on level ground and not out on the Rubicon in the middle of winter.
somers is offline
post #7 of 13 Old 04-10-2012, 03:01 PM
somers
2010 MK Patriot
I run my patriot at 40 PSI ....... 215 / 60 / 17 which is a little harsh as you say but at least i am not riding up on the side walls because i went on the tire manufacturers web page who said 40 for city and 35 highway i droped the pressure to 38 for a few hours the ride was the same i am not on the highway doing 70 mph.
i chewed up the tire side walls a little on my RAV 4 because of under inflation that information which i got from the vehicle book.
Last edited by somers; 04-10-2012 at 03:04 PM. Reason: Correction of numbers reversal.
somers is offline
post #8 of 13 Old 04-10-2012, 03:12 PM
somers
2010 MK Patriot
Some manufacturers will bump the tire pressure up beyond that which is recommended on the door jam sticker because it is not know how long the vehicle will sit on the dealers lot.
Do check you tires before you take delivery .
i took delivery of a sports car and found the the tires were up to 50 PSI+/- the car virtually had no rolling resistance.
Buyer be ware !
somers is offline
post #9 of 13 Old 05-22-2014, 04:59 PM
somers
2010 MK Patriot
If you are interested to see if the correct amount of tread is meeting the road and you are not chewing up the tire where the side wall meet the tread , take a piece of chalk and run it across all the tires take your car for a drive you will soon see if you are riding on the tread , you can do the same trick using a tire protestant on the sidewalls
over or under inflation can have an adverse cracking affect in time on the side walls
somers is offline
post #10 of 13 Old 05-22-2014, 05:32 PM
somers
2010 MK Patriot
With respect to tire pressure i have finally decided on 38 psi for my Patriot tires this directly relates yo the slow driving condition that exist in my country , however may i strongly suggest that you check you tire pressure on a weekly basis and do not forget your life saving the spare which can go for 30 days or so .
I use a paint can opener to pick the debris out of the tire tread.
My thoughts
I do not recomend that you let you tires go beloe36 PSI or excede 40 psi for in town driving .
On the highway 36 psi is good as the vehicle experiances aero dynamic lift at highway speeds.
If you pick up a nail etc deal with it imediately and change the wheel out.
Never ever let a gas station jockey inflate your tires. do it your self.
HINT
Check your engine oil level to marks often.
A clean vehicle is a happy vehicle.
somers is offline
post #11 of 13 Old 05-30-2014, 12:45 PM
ODubhGhaill
2014 MK Patriot
Factory recommended tire pressure for my wife's 2014 Patriot with Firestone Affinities is 32psi, while my FDII with Goodyear Wrangler SR-A is 35psi. I would suggest keeping the pressure at the factory or tire manufacturer's specs. Be aware of the pressure changes occurring due to temperature - 35psi at 55 degrees F jumps to near 38psi at around 75psi, both measurements taken "cold." Winter is really difficult to judge, when one day is -15F and the next is mid to upper 30sF. A good pressure gauge is crucial.
ODubhGhaill is offline
post #12 of 13 Old 05-31-2014, 10:36 AM
somers
2010 MK Patriot
I can not over stress the importants of maintaining the correct tire pressure which depends on many factors with respect to location and driving conditions in you area the are limitation and tis depends on your selection of tire.
i am a litt;e disapointed that JEEP did not develop the wheel well and arches to suit a wide variety of tire shapes and styles after all yhe apatriot is a jeep and we all know what jeeps do after the end of a hard days at the office.
somers is offline
post #13 of 13 Old 05-31-2014, 07:23 PM
222Doc
222Doc's Avatar
FIAT is the answer. Jeep wrote the book. Fiat did not read it.
222Doc is offline
tire pressure monitor problem on Compass jeepsternj Jeep Compass & Patriot Forum 23 08-01-2017 01:10 PM
tire pressure warnings Bockwinkle Jeep Compass & Patriot Forum 8 05-22-2014 04:49 PM
Too much tire pressure on riot? burrell9 Jeep Compass & Patriot Forum 8 03-29-2009 01:07 PM
Tire Pressure (TPMS) jasper1022 Jeep Compass & Patriot Forum 5 03-02-2008 09:40 AM
Tire Pressure Monitoring System echocat22 Jeep Compass & Patriot Forum 6 01-08-2007 10:39 PM
